will 265/75/16's fit on 8" wheel okay?
01-09-2011, 02:40 PM
on
found a set of wheels priced good that are 1" larger than my stockers.
tires on my current rims are oe size, different brand, but a nice e rated tire.
would these go on okay?
01-09-2011, 02:42 PM
on
should go on just fine. I wouldn't go any larger on wheel with out going up in tire size, but 265s on an 8 in shuold be fine.
01-09-2011, 02:46 PM
on
Quote:
Originally Posted by
tritonman2001
yeah, i'm not looking for anything crazy, just a little look over the stockers
01-09-2011, 02:47 PM
I believe our stock rims are 7 inches wide so yes, your cool. Just corrected.
Reason: Corrected
01-09-2011, 02:48 PM
on
big poppa
I believe our stock rims are 7.50 inches wide so yes, your cool.
my oasis says 16x7 rim size
just double checked it again
01-09-2011, 02:53 PM
on
big poppa
That size is from outside to outside. The stamp on the wheel 16x7 is from inside lip to inside lip.
Your right, just checked myself...
01-09-2011, 04:21 PM
on
beefcake
I would check to make sure the offset on the new wheels will fit on your truck. I had a guy and the ford dealer swear the rims off his/a 06 f250 would fit my 2000. f250. The front rubbed against the leaf spring when turning and the right rear rubbed against the brake shield. I was able to sell and break even, but what a pain. May not be your case at all. just fyi
ct diesel
Fifth Wheel & Gooseneck RV Towing
17
08-28-2017 02:36 PM
Trap_Shooter
10-30-2016 05:21 PM
Telestar
24
10-30-2016 09:05 AM
chris starscream
1961 - 1963 F100 Unibody
10-21-2015 03:56 PM
anthonym92
09-13-2015 07:17 AM
16 ,
16x7 ,
265 ,
26575 ,
2657516 ,
75 ,
8 ,
econoline ,
fit ,
fits ,
ford ,
rim ,
rims ,
size ,
wheel
