Wheel size for tires??
Old Jul 31, 2006 | 07:55 PM
MIKESANDS's Avatar
MIKESANDS
I know that I should already know this but...I have 37 x 12.50 R 17 LT tires, what size wheel do those fit on? I know they are 17" diameter but what width do I need? 12.50 is a ratio right? so how do you figure wheel width? thanks!
Old Jul 31, 2006 | 08:04 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
it is L/W/rim diameter
your tire is 37" tall, 12.5" wide, and fits a 17" rim. for a tire that wide i would think a 8 or 9 inch rim would suffice.
metric tire sizes are a bit harder to understand, but i can tell ya if you need.
Old Jul 31, 2006 | 08:17 PM
MIKESANDS's Avatar
MIKESANDS
Thanks
Old Jul 31, 2006 | 10:45 PM
BobbyDiesel71's Avatar
BobbyDiesel71
what brand of tire?
pics?
i am running 315/70R17 BFG AT KO's on 17x9 ProComp Extreme Alloy rims
Old Aug 1, 2006 | 05:43 AM
DUCK FAT's Avatar
DUCK FAT
Smile
I WOULD GO WITH A 10'' WIDTH RIM.
ALOHA, DUCK FAT
Old Aug 1, 2006 | 08:01 PM
MIKESANDS's Avatar
MIKESANDS
Originally Posted by toyota hauler
what brand of tire?
pics?
BF Goodrich...ok, so what about the 315/70R17 say's 9" wide rim? how do you figure that out?
Old Aug 1, 2006 | 08:08 PM
MAKO314's Avatar
MAKO314
correct me if I am wrong but I think a 315 is just about the same as 35 12.5 if so mine are on 9 3/4 rims
Old Aug 1, 2006 | 08:11 PM
PowerstrokeJunkie
a 315/75r16 tire is 12.5 inches wide (12.4 to be exact if you do the calculations) and is 34.6" tall.
Old Aug 2, 2006 | 09:40 PM
matt21418's Avatar
matt21418
315 refers to the width of the tread in mm
70 is the ratio of the tread width and the tirewall height
and 17 is the wheel diameter.
So I am able to see that this has a tread width of 315mm = 12.4 inches, and a tire with a width of 12.4 inches can go on a 8 or 9 inch wide rim.
When you start to get into tires that have a tread width of 14.5 inches you should be using a rim with a width of 10 inches.
315 mm * 70% = 220.5 mm = 8.68 inches of tire wall height.
So to get total tire height it is rim diameter plus (2 * tire wall height)
17 + (2 * 8.68) = 34.36 inches
Old Aug 2, 2006 | 09:43 PM
MIKESANDS's Avatar
MIKESANDS
So I am able to see that this has a tread width of 315mm = 12.4 inches, and a tire with a width of 12.4 inches can go on a 8 or 9 inch wid rim.
Thanks! I guess I was making too much of it? I thought there was a calculation or something. I appreciate it!
Old Aug 2, 2006 | 09:52 PM
PowerstrokeJunkie
yep, the first number is in millimeters. divide that by 25.4 to convert it to inches.
the second number is a %age of the first number. so, .7*315= 220.5 220.5/25.4= 8.68. this is the amount of sidewall. multiply by two to get two sidewalls, (17.36) and then add the wheel diameter (17) and you have a 34.5" tire.
