Graphing OBD Data from Torque
Old Mar 26, 2014 | 09:06 PM
Pikachu's Avatar
Pikachu
With more and more people using Torque Pro, I was wondering how many of you would find it useful to be able to take a .csv log file from Torque and upload it to a web site, select the data to use and have it spit out a graph you could save. If the response warrants it, I may work on coding something up in my spare time.
Old Mar 26, 2014 | 09:12 PM
gradyc's Avatar
gradyc
wellhead
That would be great. Reps to you,,,
Old Mar 26, 2014 | 09:47 PM
Dan V's Avatar
Dan V
AE as well? With cool colored lines?
Old Mar 27, 2014 | 04:02 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
That would be cool. But its also not hard to do with excel. I've got a video on it in production. If you can create a sort of drag and drop site, that would probably benifit the less technically inclined.
Old Mar 27, 2014 | 05:35 AM
Tugly's Avatar
Tugly
Here are the issues the person logging needs to take into consideration: The number of scales allowed.
How to line up symbiotic data (like IPR and ICP).
Setting realistic maximums.
Try to "synchronize" maximums - like limits of 3500, 350, and 3.5.
Color coding and line modifying (like dots and dashes) to prevent confusion.
When the user just grabs AE and uses default maximums - those maximums are for other vehicles, like gassers. 8000 RPM max? Really?
Old Mar 27, 2014 | 07:24 AM
HKusp's Avatar
HKusp
Yeah, I wish AE would save the parameters you set from the last session. It is a real PIA to have to o in a scale them every frickin time.
Old Mar 27, 2014 | 07:25 AM
Pikachu's Avatar
Pikachu
I'm not sure what file formats AE will export, but if .csv is one of them, it would work with what I've got in mind. And yes, with the cool colored lines! A graph isn't a graph without cool colored lines
Old Mar 27, 2014 | 07:29 AM
HKusp's Avatar
HKusp
AE defaults to .csv so if you code it as a drag and drop like Trey suggested, it should still work.
Old Mar 27, 2014 | 07:43 AM
Tugly's Avatar
Tugly
ahem...
From the class (I know... buried deep in 40 pages):
Set up your PIDs the way you like them for a particular purpose.
Name that session (in a location you can find again) that tells you the purpose. Then, when you start your next connection, select the purpose of the session:
HRTKD
Oct 14, 2024 07:06 AM
bigb56
Mar 16, 2015 08:05 PM
the_auto_tech
Nov 6, 2013 02:23 PM
Pitcrw6
Apr 4, 2012 10:38 PM
cdiddy
Garage & Workshop
Feb 28, 2007 11:15 PM
