what do u guys think?
Old Mar 26, 2014 | 12:06 AM
RaceDog's Avatar
RaceDog
Working on a 2004 f-250 LXT superduty 6.0 L work on a few trucks with hard start problems but this one havent seen so what do u think? pic of scanner
guess cant upload anyway
Codes P0261,P0264,P0267,P0270,P0273,P0276,P0279,P082,
P0611,P0671 and P1000
Old Mar 27, 2014 | 08:58 AM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Powerstroke Diesel forum.
Old Mar 27, 2014 | 09:02 AM
2006lariat's Avatar
2006lariat
I think the FICM is in need of a look over.
Old Mar 27, 2014 | 09:10 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
8 injector codes and the "Your FICM is toast" code. I would have to agree. FICM repair is needed. Check all 3 FICM readings. KOEO Cold, then hot motor, then throttle up for readings
Also, work back words through the electrical system to the batteries and make sure it is working properly. Grounds are good, load test each battery, alternator working.
Old Mar 27, 2014 | 01:24 PM
RaceDog's Avatar
RaceDog
we started with starter witch was bad Yes we replace FICM and now the codes are gone we notice the altnator was not working replace it all is good only code we have is number 1 glow not working well that still make it hard to start? and after it was running seems to serge,i also notice the oil PSI take at least 10 sec to come up to PSI befor start if it starts so now im thinking the fitting problem.......feed back good
Old Mar 27, 2014 | 01:28 PM
amdriven2liv
Have any live readings?
Old Mar 27, 2014 | 01:37 PM
RaceDog's Avatar
RaceDog
no yet check it out if is runs.have any ideals
Old Mar 28, 2014 | 11:24 PM
RaceDog's Avatar
RaceDog
High psi oil pump is only 350psi and i think its 1500 but iam now looking at fitting leak or injector O-rings am i on the right trail? read all stuff about them problems this trucks have, just broke 100000 miles .......
Old Mar 29, 2014 | 09:18 AM
npccpartsman's Avatar
npccpartsman
Are you using an OEM oil filter and cap?
Old Mar 29, 2014 | 09:58 AM
mustang_309's Avatar
mustang_309
Will it start with the ICP sensor unplugged? What are the ICPV's at KOEO? If the ICPV's at KOEO are .18 - .24 the ICP is likely fine and if it is you will need to air test the system through the ICP port and command the IPR closed and listen for leaks at the oil fill tube, the CCV port in the drivers side valve cover and the oil filter housing with the filter and cap removed, depending on where you hear the air will determine what you will be taking apart. My bet is the HPOP has gone ****-up. If you hear air gurgling through the oil filter housing it will confirm a bad HPOP
Old Mar 29, 2014 | 01:22 PM
amdriven2liv
What are the IPR readings while cranking?
Where at in Oregon are you?
By the way, is this a late build 04? Or, an early build 04?
Old Mar 29, 2014 | 03:08 PM
BLADE35's Avatar
BLADE35
What order did you replace in
I saw once a guy did FICM then ALT and Killed new FICM
Artisanbilt
Mar 3, 2014 01:07 PM
sluder23
Feb 20, 2014 08:20 AM
rhillman75
Nov 2, 2013 03:24 PM
2stroke
Apr 1, 2012 05:31 PM
KJG20036.0
Dec 22, 2010 09:32 PM
