6.0 jerking problems
Old Feb 17, 2014 | 03:47 PM
sluder23's Avatar
sluder23
hello everyone, I'm new to this forum and was wondering if anyone could help me on the problems I'm having with my 2007 6.0 diesel. I do have a lot of miles on the truck but keep good oil,filters, and service on the truck regularly. After I start the truck it runs ruff until it warms up. Just a little white smoke comes out at start up only. I'm loosing no water. When i get around 65mph the truck will start to jerk then eventually smooth out. my gas milage has drop down also. I have replaced the egr and put a half shell in the ficm. I checked the batteries and cables. All are good. The ficm still only gives around 42 to 43 volts. Check engine light is on also. I havent got the codes yet. Any ideas on what it could be ? I would also like to buy a diagnostic coder. Does anyone have an idea on a good code reader that want hurt the pocket book to bad?
Old Feb 17, 2014 | 05:10 PM
npccpartsman's Avatar
npccpartsman
If the FICM is under 45V it's failing or failed. You also need to get us the codes since you may have more than one issue.
Old Feb 17, 2014 | 05:12 PM
Rusty Axlerod's Avatar
Rusty Axlerod
The code will likely set you off in the right direction. FICM is going away though.
As far as code readers, if you have a smart phone check out DashBoss for iPhone or the Torque app for android. If you have a laptop around the house I can recommend a free software program called FORScan. You'll need a OBDII adapter for whichever option you use. Amazon has good prices on ELM adapters except for iPhone. Check the DashBoss sight for those. As far as a handheld mechanic type scanner I can't make any recommendations. The first only one I bought wouldn't do "live" data which I found out very quickly I wanted. So your looking for CAN bus compliant with freeze frame and live data capability on those.
Welcome to FTE!
King-bRanch's Avatar
King-bRanch
42-43 volts outta the FICM is NO good....Junk
See Ed @ FICMrepair.com
Scangauge is the cheapest form of reader (available at AutoZone i believe) for the 6.0 but dont ask me the Codes to put into it cause i have an Edge Unit
Edit...U fella's answered fast, as i was typing
Old Feb 17, 2014 | 07:35 PM
jswartz84's Avatar
jswartz84
Is the vibration motor (rpm) related or speed only. Could be a carrier bearing.
Old Feb 17, 2014 | 10:55 PM
felix4's Avatar
felix4
Welcome to FTE!
^^^What he said
Torque Pro with bluetooth OBDII adapter $25. Don't waste $140 on a ScanGauge II. FICM volts are low.
Old Feb 18, 2014 | 09:53 AM
sluder23's Avatar
sluder23
thanks guys for the help, as soon as i get the codes i will post them. Justin the jerking is gas related. Thanks again for the help and advice on the programmer. Give me a day or so to post the codes.
Old Feb 18, 2014 | 10:15 AM
dvldog13's Avatar
dvldog13
FICM is toast............see ed @ ficmrepair.com............also sounds like some stiction issues......
Old Feb 19, 2014 | 03:38 PM
sluder23's Avatar
sluder23
codes found
ok guys I have the code finally. The only code was a P0470 Exhaust Pressure Sensor. Whatever this is, They couldn't show that they had the part
Old Feb 19, 2014 | 05:41 PM
Rusty Axlerod
EBP sensor info is used buy the PCM to operate turbo (among other things). It mounted on a hard line that comes off the driver side exhaust manifold. It's worth a shot to remove it and clean it as it can get clogged up with exhaust soot. Inspect the electrical connector and wiring, clean the sensor, and push something down the tube to make sure it's clear. A piece of weed wackier line seems to be the tool of choice.
Old Feb 20, 2014 | 08:20 AM
sluder23's Avatar
sluder23
Thanks a lot for all the information. I will try this tonight and let you know
2000 Ex-cursion
Mar 20, 2015 08:47 AM
EXbowtieguy
Jan 6, 2012 05:55 PM
soybeaner
Nov 23, 2011 05:00 AM
majkthreads
Apr 8, 2011 10:03 PM
Portagie68
Mar 23, 2011 05:37 PM
