spare tire
Old Apr 4, 2014 | 11:39 AM
For-dragon's Avatar
For-dragon
See parts catalog pic in post 5.
353735-S100 .. Bolt-Channel to Frame-left (drivers) side / 1/2" -13 x 10 1/2" long / Obsolete
GREEN SALES CO. has 1.
NOS PARTS LTD has 2.
KLIMESH MOTOR SALES has 13.
Bill, can you re-check to see if this is the right number? I cannot find it on the supplied pic from the catalog. (I also don't see anything for the '66, but assume the frame is the same back there for the '65.) I called Green and they had no idea what bolt I would need and had neither of the numbers listed. Interestingly the carrier bar (C5TZ-1443-A) is also sold by Green used. Hardly seems NOS? Is that normal?
Thanks
Old Apr 5, 2014 | 07:51 AM
Shadowrider123's Avatar
Shadowrider123
My 66 LWB has the spare underneath.
Its a 235/75R15 and is really to big to fit properly.
I have a 225/70R15 that Im going to mount and see if fits better.
When mounted which way does the outside wheel face? Toward the ground or the bottom of the truck bed?
Old Apr 6, 2014 | 10:47 AM
Shadowrider123
Anyone?
Does the wheel mount with the mounting surface pointed to the ground or to the bed of the truck?
Old Apr 6, 2014 | 11:08 AM
jtmassie's Avatar
jtmassie
Spare Mount
In the photos posted by SuperSabre it looks this the inside of the wheel faces down.
Old Apr 6, 2014 | 04:31 PM
jowilker's Avatar
jowilker
Originally Posted by Shadowrider123
Anyone? Does the wheel mount with the mounting surface pointed to the ground or to the bed of the truck?
Don't know that it really matters, I have done it both ways.
John
Old Apr 6, 2014 | 05:13 PM
Bill W's Avatar
Bill W
Bob, your spare is upside down
John
the outside of the rim faces down, towards the ground... if i remember right the original jack sets inside the rim while secured under the truck.
Old Apr 6, 2014 | 10:59 PM
SuperSabre's Avatar
SuperSabre
In the absence of any guidance at the time I hung my spare tire, I decided to have the outside down to make it easier to reach the valve stem to check tire pressure. It seems to work OK so maybe John is right in that it doesn't matter one way or the other unless you can make your jack storage work as you say. It seems to me that I was once told - don't remember by whom - that the jack for the '66 was stored either behind or under the seat. Maybe that was just where he personally stored it. Since my jack is stored in my toolbox, it's not an issue for me.
Old Apr 7, 2014 | 05:33 AM
jowilker's Avatar
jowilker
I stopped hauling mine around under the 66, but the valve stem would go down if I were. That is the way I have it under the 06.
Mr. Bill, You put yours under the way that make you feel all warm & fuzzy.
John
FLgargoyle
Mar 3, 2019 04:18 PM
Brigart
Jul 6, 2013 08:08 PM
Skyline Drive
Dec 22, 2011 10:27 AM
Edw
Oct 7, 2011 04:53 PM
GolferSA
May 4, 2002 11:36 AM
