spare tire
Old Mar 25, 2014 | 08:01 PM
pipeliner83's Avatar
pipeliner83
spare tire
has anyone put the spare under bed like they do on newer trucks. wondering what would be the easiest way to do it
Old Mar 25, 2014 | 11:11 PM
SuperSabre's Avatar
SuperSabre
When asking for our help, it is always useful if you provide us with some information about your truck: Year? Model? Bed Style? Wheelbase? Location of fuel tank if modified? To give you a general answer, On my '66 long wheelbase Styleside with stock fuel tank location I was able to go to the junkyard and find the pieces I needed to mount my spare wheel/tire under the truck at the very back. Make sure the junkyard truck has the same size wheels that your truck has. I will attach some pictures. Hope this helps.
Old Mar 25, 2014 | 11:38 PM
Tedster9's Avatar
Tedster9
In 64 the Longbed F100s have the same stowage, so that would be one way to do it, assuming you can find part numbers, and of course parts.
Sent from my iPhone using IB AutoGroup
Old Mar 26, 2014 | 08:41 AM
schoo's Avatar
schoo
Or you have a partstruck, I have 3/4 of the parts from a 65' need one bolt at the fixed end will have fab it to work
Old Mar 26, 2014 | 10:04 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If 1961/66's were ordered with an optional spare, the usual location was under the bed at the rear.
An option on Stylesides was a bracket that allowed the spare to be mounted vertically inside the bed, usually seen on the left side, just behind the cab.
Flaresides were available with another option: Spare could mounted on the left...outside of the bed using a bracket, along with the left rear fender that had a cut-out for tire clearance.
Left upper: Flaresides & Stylesides / Right: Stylesides / Left lower: Flaresides.
Old Mar 26, 2014 | 10:10 AM
pipeliner83
thanks guys have a 1965 SWB with a gas tank from a ford ranger under the bed. forgot to mention that when I posted it the first time. I have the room in the back for it just wanted to see hat yall thought
Old Mar 26, 2014 | 10:18 AM
Tedster9's Avatar
Tedster9
Hey ND - so 61-64 F100s had no spare anywhere unless ordered as an extra cost option? Jeez.
Reminds me I need to drop that thing and get it replaced. Pretty sure it's original, it doesn't hold air too well and probably wouldn't work as advertised. Next, can the bed mounted spare tire bracket for stylesides be obtained today anywhere? Would be interested in doing this, thinking of adding an aux fuel tank at the spare tire location.
Old Mar 26, 2014 | 10:25 AM
NumberDummy
Hey ND - so F100/350's thru at least 1979 had no spare anywhere unless ordered as an extra cost option? Jeez.
Fixed it for you...and...the spare wheel could be ordered without the tire.
See parts catalog spare tire mounting pics in post 5.
Old Mar 26, 2014 | 10:52 AM
Tedster9's Avatar
Tedster9
That would have been a good negotiating point when buying. "Where's the spare?" "Oh, that's extra sir." "Not if we're gonna make a deal..."
Old Mar 26, 2014 | 09:22 PM
For-dragon's Avatar
For-dragon
ND - Any sources for NOS under-bed spare mounting brackets/hardware ('66 lwb no mods)?
Old Mar 26, 2014 | 10:46 PM
NumberDummy
See parts catalog pic in post 5.
C5TZ-1408-C .. Bolt-Spare Wheel Carrier Support-right (passenger) side / 1/2" x 13" long including loop, thread length 4 1/4" / Obsolete
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
384581-S100 .. Clip & Blind Nut-retains bolt to frame rail / Obsolete
NOS PARTS LTD has 3.
GREEN SALES CO. in Cincinnati OH has 25 = 800-543-4959.
C5TZ-1443-A .. Channel-Spare Wheel Carrier / Obsolete
GREEN SALES CO. has 2.
353735-S100 .. Bolt-Channel to Frame-left (drivers) side / 1/2" -13 x 10 1/2" long / Obsolete
GREEN SALES CO. has 1.
NOS PARTS LTD has 2.
KLIMESH MOTOR SALES has 13.
Old Mar 26, 2014 | 10:51 PM
kstones63's Avatar
kstones63
I have one that I took out of my son's 63 LWB UNI. I don't know if it is the original factory unit or if it was added. I have the mounting bolts, the flat plate that the tire goes up against and the tire rack.
Kevin
Old Mar 26, 2014 | 10:58 PM
pipeliner83
im gonna either make one or get one from the junk yard. cant be to hard
Old Mar 26, 2014 | 11:01 PM
pipeliner83
i just hope that my truck can one day look half as good as yours does. that is a slick truck
Old Mar 26, 2014 | 11:02 PM
NumberDummy
There are enough NOS parts listed in post 11 for two complete under bed spare tire carriers.
