E4OD to ZF5
Old Mar 26, 2014 | 01:46 PM
madpogue's Avatar
madpogue
Brian builds manuals?
I doubt the dealer would do it. They do maintenance and repairs, even major ones. But they shy way from what they consider "alterations". They don't have a specific procedure to do it.
Old Mar 26, 2014 | 02:51 PM
ReBilld's Avatar
ReBilld
Originally Posted by DougJ_1997PSD
where is your shop ReBilld? i would like to try and do this myself, but i also want to talk to my ford dealer in the area
I am in Southern WV, just outside of Beckely. It's just my shop here at my house. I doubt you'll be able to find a shop that would or could do the swap, and if you did, they would charge you an arm and a leg, and I doubt a Ford dealership would even touch it. If you wanted to make they drive here to my house, I would do all the work for your E4OD, and it would only cost you the fuel to drive down here.
Old Mar 26, 2014 | 04:10 PM
DougJ_1997PSD's Avatar
DougJ_1997PSD
Maryland Performance Diesel is relatively close, and ive heard good things about them. WV is a bit far, especially with my 4.10 rear axle! but like i said, i would like to do the build myself. i found a nice looking new (im assuming) one at Ford ZF 5 Speed Transmission Sale | S5-47, S5-42, S5-47M
have you guys heard anything about these guys? i might get it shipped to here.
Old Mar 26, 2014 | 04:52 PM
madpogue's Avatar
madpogue
That ^^^^^^ is a reman tranny. A new one would be many, many dollars more. The main paragraph on that page actually has a scroll bar to the right; there's more to read, with a little info about the reman work.
Old Mar 26, 2014 | 06:21 PM
tshrager's Avatar
tshrager
Originally Posted by fordpride
If your going to pay a shop then you should just get a BTS trans built.
Once again, Mike is spot on. I'm pretty sure you're going to have sticker shock once you buy the parts and factor in labor. That and having a "shop" do it does not quantify as doing it yourself...
Old Mar 26, 2014 | 06:30 PM
fordpride's Avatar
fordpride
Originally Posted by madpogue
Brian builds manuals ?
No he doesn't. I saying that by time you by the parts and pay someone to do the swap you could have got a BTS auto
Old Mar 26, 2014 | 08:12 PM
madpogue's Avatar
madpogue
Um, but isn't the OP's objective to have a manual transmission?
Old Mar 27, 2014 | 12:23 AM
JCart's Avatar
JCart
Did this mod couple years ago on the Red sig truck. i am fortunate in that I had a complete parts truck so it was basically unplug/unbolt and swap. To keep track I used Zip Lock bags and boxes to track all parts for each truck respectively and labelled each bag. Basic tools is all you really need. I did buy a set of really long extensions for a total of 4-5 feet to make it easy to undo the tranny to block bolts. Also some long Jack stands to support the rear of the truck and lift it really high makes it easy to drop tranny and T case. It's not that bad a job just do your research, track parts and do it. If I can anyone can hahaaa.
jrc
Old Mar 27, 2014 | 07:26 AM
TyBragg's Avatar
TyBragg
Welcome to FTE! I'd say you'd have a hard time finding a shop that has ever done this before, and I wouldn't let them mess with it unless they'd done it before. No one likes to be the guinea pig. You'll find more expertise on here than probably anywhere else. I've also done several of these swaps (right along with Bill - he's my father in law). It's not rocket science, but it does take a fair amount of research. Here's a link to my swap thread, which has a lot of good documentation mixed in with the usual BSing of us guys on here. It's worth a read if you are serious about doing this yourself. There are several other threads with great documentation as well (I just don't have the links handy, but you can go to "search this forum" on the main page of this forum and use that to find the other threads). And there are some good links in my thread as well. Several on the first page.
https://www.ford-trucks.com/forums/1...n-process.html
Old Mar 27, 2014 | 10:39 AM
BBslider001's Avatar
BBslider001
What?! I'd almost take you up on this all the way from California! That's a pretty good offer!
Old Mar 27, 2014 | 02:37 PM
ReBilld's Avatar
ReBilld
If you had all the parts and drove all the way here from Cali, I'd do it for you! But your trans wouldn't do me any good.....I need a 4x4 E4OD
Old Mar 27, 2014 | 03:33 PM
quesey's Avatar
quesey
thought you had 1?
Old Mar 27, 2014 | 05:19 PM
  #28
DougJ_1997PSD
This looks really helpful, thanks! I'm going to continue doing a lot of research on this topic and scout out my local junkyards. I would like to do this all in my driveway, so it will be a little difficult. Thanks again for the help everyone!
Old Mar 27, 2014 | 10:02 PM
  #29
ReBilld's Avatar
ReBilld
Originally Posted by quesey
thought you had 1?
I need a good one. LOL! The one I have needs rebuilt, and the one in my son's truck we don't know if it's good yet. I guess we'll find out tomorrow maybe
Encho
Sep 5, 2013 06:22 PM
renegade14
28
Apr 5, 2010 12:48 PM
Norton72
Nov 13, 2008 12:23 AM
otpracer100
Feb 21, 2006 06:10 AM
