E40d fault code 94
Old Apr 9, 2014 | 05:26 PM
giorgio.fo's Avatar
giorgio.fo
thanks for the help
FORDF250HDXLT!!
replace the harness and the tranny fault codes are gone. still can't get the 111 cause a problem with the tps. it's fault code 23. i already replaced the senso and the connector. adjusted the tps.. now i have 1 at idle, 4.06 (center wire) and 5 bottom wire. can't get any better cause i'v alredy rotated the bracket all the way. checked the ohm too.. i get 0.66. i'v inspected the wires all the way..seems ok. when driving sometimes won't downshift properly.
Old Apr 9, 2014 | 05:43 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
oh good deal.your doing really good.
but don't give up on the FIPL/TPS setting.go for 1.2V idle and someplace over 4V WOT.she'll downshift correctly then.i know it can be tricky but it is possible.
don't forget the FIPL (fuel injection pump lever) /TPS (throttle positioning sensor) - code 23 will be tossed if you don't hold WOT (wide open throttle) during the entire scan even if it is good and set correctly.
1.0v idle she wont shift properly.likely way too early as your experiencing but it is a little surprising to see he TECA doesn't like it enough to toss 23.even if it didn't toss 23 though.you wouldn't want to keep it there.you want it shifting perfect.keep at it.
there are some more tips about finding the correct axis to hit both idle/wot voltages in the main tps thread found here:
E40D FIPL/TPS
Old Apr 13, 2014 | 11:01 PM
giorgio.fo's Avatar
giorgio.fo
thanks for the help!
spent a lot of time setting the tps. now i have 1.20 idle, 4.23 WOT and 4.95 (bottom wire). i'd say it's preatty close..! it now shifts better but sometimes still "kicking" when upshifting from 1st to 2nd gear.. it goes over 2000rpm..and it won't downshift properly.
really don't know what it could be..
FORDF250HDXLT
21
Mar 16, 2026 09:43 AM
Jm93
Mar 10, 2019 10:47 PM
musicars
Nov 7, 2015 11:54 PM
94Bronco2215
1978 - 1996 Big Bronco
Sep 3, 2015 06:21 PM
desertdogs
Nov 12, 2008 07:58 PM
