E40d code 62
Old Mar 4, 2019 | 09:18 PM
Jm93's Avatar
Jm93
E40d code 62
hello this is my first post, I’ve learned a lot from this site. I have a 1993 Ford F-250 7.3 idi 4x4 extended cab. Currently I’m getting code 62 the solinoid pack, accumulator, springs, valves, and tps have been replaced. I’m assuming tps is fine since I’m not getting a code for that. It is set to correct voltage. Trans shop replaced a broken wire going to the harness. The symptoms I’m getting are when I get up to highway speeds/ overdrive I get the code. No slip An fluids look good. I decided to do some digging around An look like the previous owner spliced a wire going to range sensor. So I decided to replace all the wires on the trans harness for piece of mind. I found a broken wire coming from the main harness the pcm I believe? Have yet to split those wires open yet looks like it goes to the fuse box then down to trans harness connecter i was wondering if anyone had any wiring diagrams from pcm to fuse box under the hood an so on. Sorry for the long post an appreciate anyone’s input.
An hope I’m posting right lol.
Old Mar 5, 2019 | 07:58 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Code 62 cannot set from a wiring issue unless there is also a code for a wiring fault. Since you don't have a code for a wiring fault I'm 99.9999% sure you don't have any problems with the wiring.
This code sets when there is slip. You say you don't have slip, but you don't know that. It only takes 50 RPM slip for a second to set the code. Can you really tell that the engine is at 2550 RPM when it should be at 2500 RPM? I can't.
Remove the inspection cover from the transmission bellhousing. Look at the front face of the torque converter. The whole converter should be unpainted steel. Is the front face discolored? It tends to get blued when code 62 sets, due to slippage of the torque converter clutch. If it's discolored you need to replace the torque converter.
Old Mar 5, 2019 | 08:53 AM
Jm93's Avatar
Jm93
I will definitely give that a look, off topic but the wire that is broken appears to be purple I cannot tell the stripe color yet until I clean it really well. Is there a purple wire that goes to the trans harness on passenger side that is purple for the torque converter clutch? Just from different things I’ve been reading shows a pin out of the trans harness connector. I’m sure it is unfortunately the converter it’s self but want to fix an rule everything out before replacement. Thanks again for the tip on checking converter.
Old Mar 10, 2019 | 09:24 PM
Jm93's Avatar
Jm93
Hey mark what is a good converter to get an where to get it from
Old Mar 10, 2019 | 09:25 PM
Jm93's Avatar
Jm93
And also the only other thing I haven’t changed was the pcm the converter doesn’t look blue to me, but I need to pull it to check it anyway
Old Mar 10, 2019 | 10:10 PM
DarkOverCast's Avatar
DarkOverCast
If you decide to replace the converter I would highly recommend you also replace the front pump while your in there and install a new seal. It's easy enough once the converters out.
Most times when a converter fails it takes the front pump with it..I wouldn't risk it if I had it all apart
Old Mar 10, 2019 | 10:47 PM
Jm93's Avatar
Jm93
Okay good to know thank you
NinthGenF-SeriesOBS
Apr 24, 2016 01:09 PM
NinthGenF-SeriesOBS
Mar 26, 2016 09:47 PM
buba 11
Large Truck
Sep 3, 2011 10:15 AM
HVJ
Jan 21, 2005 12:10 PM
pigsew
May 27, 2001 04:03 PM
