Is my engine totalled?
Old Mar 27, 2014 | 07:42 AM
  #31
Gary Lewis's Avatar
Gary Lewis
If the crankcase is overfull that oil is going to go somewhere. And if it is thinned by gas then it will go past seals much easier than oil.
Old Mar 27, 2014 | 08:06 AM
  #32
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Exactly my thinking in post #21 Gary.
Be aware that a hydrolocked engine can easily bend a rod.
Old Mar 27, 2014 | 09:11 AM
  #33
reamer's Avatar
reamer
Ripped Fuel pressure regulator can add huge amounts of gas to the pan.
Pull the vac line off the regulator, if is squirts gas out, the regulator needs replacement.
(hydro-locked my 90 ranger that way)
Old Mar 27, 2014 | 09:18 AM
  #34
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
That vacuum line is connected to the #8 intake runner on a 302, correct???
Old Mar 27, 2014 | 09:26 AM
  #35
reamer's Avatar
reamer
I don't remember... But if ANY gas comes out the vac port on the regulator, that's bad news.
Old Mar 27, 2014 | 04:42 PM
  #36
Eddiec1564's Avatar
Eddiec1564
I recall the PFR vacuum line is centered in the middle of the upper intake for the 302/351 engines. Then drains trough the PCV valve on the bottom of the upper intake.
wdholmes
1978 - 1996 Big Bronco
Dec 16, 2016 10:20 PM
Izzy3110
1983 - 2012 Ranger & B-Series
Aug 17, 2011 08:33 PM
mustangman
Sep 23, 2005 10:01 AM
1968stepside
Feb 29, 2004 12:27 AM
bjensen
Oct 19, 2003 09:39 PM
