Transmission fluid Capicity
Old Mar 22, 2014 | 08:41 PM
49m47's Avatar
49m47
Greetings everyone,
I was changing the fluid in my transmission and ran into a confusing situation.
The book say 2 3/4 pints for 3 speed and 6 pints for 3 speed heavy duty.
Normally you have a drain plug and a fill plug. I'm good so far.
I put in 2 3/4" pints but its no where near coming out the fill plug. As a matter of fact if I stick my finger in I can not reach oil.
So either it takes 2 3/4 pints and fill plug hole is not relevant to the quanity of oil or its a Heavy duty and it takes 6 pints.
How can I tell?
Thanks
Old Mar 23, 2014 | 08:11 AM
carnut122's Avatar
carnut122
First, I'd ensure there are no other "fill holes," then I'd fill it 'till it runs out of the hole you are using. Next, I'd put the plug back in and drive it.
Old Mar 23, 2014 | 09:52 AM
big job's Avatar
big job
Dave, are you sure you read the book correctly or a misprint. I come from
back in the day of these things and these capcities were measured in
pounds. So it would be 2 3/4 lbs. I still have the 'cant remember the name'
pumper holds 5 gals of gear oil my father bought in the 1940s, the dial says pounds of gear oil not pints. Oh its an Alimite Co. product............
Old Mar 23, 2014 | 08:21 PM
49m47's Avatar
49m47
It shows in the book as 2 3/4 PTS, 6 PTS and so on. I'm going with pints.
Maybe there is something in the book that will help me figure out if it is a standard 3 speed or heavy duty 3 speed.
Well thanks
Old Mar 23, 2014 | 08:35 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Well, I don't know if your truck is stock, but the Ford trucks for 49 had the 3 speed in the F1, and the 3 Speed HD was in the F2 - F5. Isn't the M47 equivalent to a Ford F1?
Old Mar 23, 2014 | 09:23 PM
49m47's Avatar
49m47
The M47 is the equivalent...... OK as a proud Mercury owner, Lets call it similar to the F1.
The shop manual that I use is for 1949-50-51 F series trucks with 1952 Supplement. It show the 3 speed heavy duty as an option on F-1,2,3,4 5 COE and Sch bus....
The manual is both a blessing and a curse..............
Old Mar 23, 2014 | 09:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
HD 3-sp was an option in F-1's. A picture would tell us immediately. The HD is much larger, rounder, case, mostly deeper and wider. (HD on top below. Ignore that the LD 3-sp below is a side-loader, same size as your top-loader)
Old Mar 24, 2014 | 04:49 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
T-87D optional 1948/52 F1, standard equipment 1948/52 F2/F3/F4/F5.
Note "Remarks" inre to F1 T-87D and that it has a different part number and uses a different parts list than F2/F5.
Left lower pic: C = F1 / D = F2 / J & JH = F3/F5 Parcel Delivery / Y = F3 / T = F5 / TL = F4 / W = C5 COE.
Old Mar 24, 2014 | 08:53 PM
49m47's Avatar
49m47
This is my first attempt at entering a picture. Lets see how I do. Looks like I got it right. My guess from the info you attached, this is a 3 speed HD. What do you think?
Old Mar 24, 2014 | 11:36 PM
ALBUQ F-1's Avatar
ALBUQ F-1
No doubt, that's a HD.
Old Mar 25, 2014 | 02:53 PM
49m47's Avatar
49m47
Its a Mercury truck..... I should have known it was HD
Thanks for the help. 6 pts it is!
tyrantsparky
Jan 16, 2015 04:34 PM
richardbrust
15
Feb 23, 2014 07:36 PM
krumpelsaurusrex
Jul 1, 2009 03:27 AM
dennisb56
17
Jun 8, 2008 08:04 PM
redchl
1978 - 1996 Big Bronco
Jan 20, 2008 12:12 PM
