Gear oil
Old Jan 15, 2015 | 03:12 PM
tyrantsparky's Avatar
tyrantsparky
Gear oil
I know this is a stupid question, but I know someone can help me on here. I have a 62 f100 with a four speed manual transmission w/ granny. It has been shifting a little rough this morning and I'm wondering if there is a place I can check the gear oil if that's a possibility. I just had the rear differential worked on and there aren't any leaks there. Any help with this would be much appreciated.
Old Jan 15, 2015 | 03:43 PM
schoo's Avatar
schoo
sounds like a t98, a square head bolt on rt side(passenger side)fill to hole
drain plug is same shape on bottom
Old Jan 15, 2015 | 03:50 PM
Roger Carter's Avatar
Roger Carter
There should be a 1/2" pipe plug about mid way up on the side of the trans main case. Passenger side if memory serves me. This plug should have a 9/16" or 5/8" square end on it.
This plug is the fill hole and where you check fluid level. Remove the plug, stick your finger in and see where the fluid level is. If the level is within 1/2" of the bottom of the fill hole I call it good. If lower, fill to the bottom of the threads and put the plug back in.
Colder weather can cause for harder shifting, but seeing as you are in the Phoenix area, weather you call cold shouldn't affect the trans.
Good luck.
Old Jan 15, 2015 | 04:53 PM
tyrantsparky
thanks for your response. Any suggestions on the type of oil to use for these transmissions?
Old Jan 15, 2015 | 05:05 PM
tyrantsparky
well I opened the plug and some oil came out. i think i have enough. If I were to change it, any tips and what fluid would you use?
Old Jan 15, 2015 | 05:19 PM
Tedster9's Avatar
Tedster9
90 wt gear oil seems to be a common modern sub for whatever they used back then.
Old Jan 15, 2015 | 09:13 PM
tyrantsparky
Anybody have thoughts on GL-4 versus the GL-5?
Old Jan 15, 2015 | 09:20 PM
Tedster9's Avatar
Tedster9
I would check the manual and find out what FORD specified back in the day, and then use whatever the closest equivalent is today. They may have used straight 50 wt motor oil back then, for example.
I've been using 75/90 for years in a three speed. Probably the wrong stuff, no problems afaik though.
Old Jan 15, 2015 | 09:48 PM
Jim Beckers's Avatar
Jim Beckers
Great info on the T-98 can be found here: The T98 Transmission - Novak Conversions
Look at the bottom of the page at the grey box and the recommendations regarding the proper oil for these transmissions. I used their advice after I worked on my t-98. Here is the product from NAPA that I used. http://www.napaonline.com/Catalog/Ca...201_0434862994
Here is the quote from the page.
"When filling your T98 with gear oil, we recommend that you select a conventional mineral oil or a para-synthetic in lieu of a full synthetic oil. Properly assembled manual gearboxes do not have the thermal strains seen by combustion engines or hypoid gears. Synthetic fluid in these gearboxes, while not harmful, is probably an economic waste.
Hypoid gear oil is sulphurized higher than transmission oil and can be mildly corrosive to the non-ferrous alloys used for synchros, bushings and thrust washers in these transmissions.
An 80W-90, API-GL5 or MT-1 rated fluid is very good. Some claim faster shifts from using a 50W engine oil in their transmission and we do not consider this to be contraindicated unless you operate your vehicle in a very warm environment."
Old Jan 15, 2015 | 10:03 PM
hiball3985's Avatar
hiball3985
I've read numerous articles in the past that recommend not using GL5 in transmissions that have soft metals like brass. I've stuck with GL4 to be on the safe side.
Old Jan 15, 2015 | 10:04 PM
tyrantsparky
Jim, thanks for jumping in the conversation. I was doing some searching and stumbled on this page. Good info here. Thanks for your input.
Old Jan 16, 2015 | 11:32 AM
daveengelson's Avatar
daveengelson
My 65 has the limited slip rear end, curious if I should go with same recommendation; 80-90 GL 4 or 5.
Old Jan 16, 2015 | 11:43 AM
tl1965's Avatar
tl1965
I've been using 50wt motor oil in my T18 without any issues even in winter.
Old Jan 16, 2015 | 04:24 PM
Roger Carter
If your limited slip is factory be sure to use a "friction modifier" additive if whatever gear oil you use doesn't include it.
Lubricant technology has changed a lot in the last 50 years, but I always use the factory recommendations as a good starting point. What works in a 2015 truck may not work in a 1965 truck, due to different materials, clearances, etc.
Old Jan 16, 2015 | 04:34 PM
hiball3985's Avatar
hiball3985
I had a new 9" third member built for my 57 by a reputable company that only does rear ends and I have used many times in the past and they told me there is no problem using GL 5. I also inquired about Royal Purple Synthetic that I planned on using he told me that was fine also..
My 60 and 66 have StaLube GL 4.
49m47
Mar 25, 2014 02:53 PM
MONAVIERONJON
15
Oct 7, 2010 09:40 PM
mybrownie
Aug 31, 2009 10:38 PM
dennisb56
17
Jun 8, 2008 08:04 PM
redchl
1978 - 1996 Big Bronco
Jan 20, 2008 12:12 PM
