1978 - 1996 Big Bronco
Steering Wheel
Old Mar 22, 2014 | 08:16 AM
Lowdog's Avatar
Lowdog
Steering Wheel
If you put a '96 air bag "square" steering wheel on an older '93 column, would the cruise control and horn still work but just not the air bag? I like the look of the air bag wheel and I have one that is in better shape than the one on my '93 Bronco.
Old Mar 22, 2014 | 05:52 PM
greystreak92's Avatar
greystreak92
If you don't get a response detailing the procedure, chances are no one here has done it. Not to say it can't or hasn't been done though. If you don't have any luck here, you might want to check the F-series forum as the column setup was identical to the Bronco.
I have no significant information to offer other than the electrical diagrams between 92 and 96 are identical in all of my reference material. That doesn't mean the physical/mechanical components aren't different.
Old Mar 27, 2014 | 12:30 AM
MilllerTime's Avatar
MilllerTime
I know the clock springs are different
Old Mar 28, 2014 | 05:41 AM
Lowdog's Avatar
Lowdog
Clock spring? I put a new steering wheel on my '96 F-350 a few years ago but I don't remember a spring. Is that deeper in the column?
Old Mar 28, 2014 | 09:04 AM
exranger06's Avatar
exranger06
A clock spring isn't actually a "spring" per se. It's a spool of wire behind the steering wheel. It's what connects the horn button, air bag, and any other electric/electronic stuff on the steering wheel to the rest of the truck. Think about it: You can't just run a bunch of wires up the steering column and connect them to the steering wheel. Every time you turn the steering wheel, the wires will get all twisted and tangled up and will break pretty quickly. A clock spring connects all the electric stuff in the steering wheel to the rest of the truck, and allows you to turn the steering wheel without wires getting twisted. You'll see it as soon as you take the steering wheel off:
Oh and MillerTime: Of course the clock springs are different! Why would Ford use a clock spring that has wires for the airbag on a truck that has no airbag??
Trucks with airbags have two connectors on the clock spring: One connector just for the airbag, and the other for the horn button and cruise control buttons. The connector for the horn and cruise may or may not be the same for non-airbag trucks, I don't know.
Old Mar 28, 2014 | 08:33 PM
Lowdog's Avatar
Lowdog
Okay, this was the info I needed. I'm gonna try it, I bet I can make it work since I won't be hooking up the airbag.
Old Mar 29, 2014 | 03:59 AM
gatorfor88's Avatar
gatorfor88
You might want to remove the airbag before you install it.
RadioControlGuy85
Feb 24, 2016 03:57 AM
bhalvorsen
Nov 25, 2010 05:55 AM
arkredneck
Jan 2, 2010 09:00 AM
jaandmk
1997 - 2003 F150
Nov 4, 2008 10:59 PM
IMCO_Performance
Dec 1, 2005 08:59 PM
