power help
Old Nov 24, 2010 | 09:12 AM
bhalvorsen's Avatar
bhalvorsen
power help
ok so my horn and cruise control have stopped working, and the air bag light keeps coming on. i checked the connectors at the bottom of the steering column and everything seems fine so the theory is that the power is not connecting somewhere between there and the steering wheel. could it be the connector that allows the wheel to spin and maintain connections at the same time?
Old Nov 24, 2010 | 10:01 AM
Terry S's Avatar
Terry S
Welcome to FTE,first of all let us know what your driving. check the fuses first if ok the problem probably lies with the clock spring in the steering wheel. Both of the items you mentioned will not work if the clock spring has gone bad. just what you suspected.
Old Nov 24, 2010 | 10:10 AM
bhalvorsen's Avatar
bhalvorsen
94 f150, checked the fuses and everything is fine
Old Nov 24, 2010 | 11:00 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE. what you are describing is classic symptoms of a dead "clockspring" assembly. it is behind the steering wheel in the upper column.
the proper ford name for it is "control assembly, air bag".
it is not very hard to do if you have mechanical ability's and common sense.
Old Nov 24, 2010 | 11:02 AM
nstueve's Avatar
nstueve
x2 on the clock spring!~
Old Nov 24, 2010 | 11:04 AM
bhalvorsen's Avatar
bhalvorsen
yup, clock spring it is. gotta wait till i can get to a scrap yard next week
Old Nov 24, 2010 | 11:33 AM
tjc transport
i ain't rite
i would just buy new. you have no idea what condition the one from the junk yard is going to be in.
check with parts guy ed.
www.partsguyed.com
if i remember correctly, his price is around $100
Old Nov 24, 2010 | 12:36 PM
bhalvorsen's Avatar
bhalvorsen
broke college student and just dropped 500 on new tires. i can afford to pull a few off of junk trucks
Old Nov 25, 2010 | 05:55 AM
TexasGuy001's Avatar
TexasGuy001
There is some info and a video in this thread the might help.
https://www.ford-trucks.com/forums/9...ontroli-2.html
