6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
CEL codes need help
Old Mar 21, 2014 | 10:01 AM
Sxeautoworx's Avatar
Sxeautoworx
CEL codes need help
Hello everyone. I am new to the diesel world and need some help. I bought my first diesel vehicle recently, an 08 F350 xlt drwd. The following codes came up when I hooked up the scanner to it.
P0684-Glow plug control module
P0420-o2 sensor or cat
P2002-dpf bank 1
P2452- ?????
What would cause these codes to go come up and what can I do to correct them? Also from time to time, my truck will let out white heavy smoke from the exhaust. It comes and goes. I've heard that diesel trucks smoke sometimes but I don't think what my truck is doing is normal.
And last but not least, wiring fault on trailer message. How can I correct that problem. Thanx in advance. Any help will be greatly appreciated.
Old Mar 26, 2014 | 08:40 AM
Sxeautoworx
can any one help me out here? 100 views and no input?
Old Mar 26, 2014 | 11:27 AM
parkland's Avatar
parkland
P2002-dpf bank 1
P2452- ?????
It sounds like you have some codes which hopefully are just sensors, or maybe loose connections.
Being that you're new at diesels, and seeing that 6.4's and newer trucks are a little finnicky and expensive to fix, I'm thinking you should either take it to the dealership, or find a friend or someone local who will tech you some of the ropes.
The glow plugs shouldn't effect how it's running once it's warmed up a bit, but DPF/emissions codes could make the truck stay in regeneration mode.
In regeneration mode, it will constantly try to clean the DPF exhaust filter, and there will be excess fuel and smoke, and poor mileage.
Old Mar 26, 2014 | 11:29 AM
parkland's Avatar
parkland
Are you hooked up to a trailer when this is happening?
Old Mar 26, 2014 | 11:41 AM
senix's Avatar
senix
Recommend clearing all codes and then start over.
Go for a drive and see what you get.
Also what are you using to retrieve the codes?
Old Mar 26, 2014 | 03:18 PM
Sxeautoworx
I'm currently getting 10.4 mpg. Not sure if that's a good thing. Also I noticed that it has excess oil in the motor. I heard that could cause the smoke. I'm gonna replace the egr and fix the issues with the codes.
Old Mar 26, 2014 | 03:19 PM
Sxeautoworx
No trailer hooked up.
Old Mar 26, 2014 | 03:21 PM
Sxeautoworx
OK thanx. I'll try that as well
Old Mar 26, 2014 | 03:36 PM
parkland's Avatar
parkland
Whoa... put the brakes on.
Don't waste money on parts till you find out whats actually wrong.
Sounds like the truck is in constant regen, and thus getting a lot of fuel in the engine oil.
Do you know for sure the EGR valve is bad?
Sounds more like some sensor or wiring issues.
Old Mar 26, 2014 | 03:39 PM
senix's Avatar
senix
10.4 and excession and p2002 code...if you have warranty take it in. You are making oil. Dumping excess fuel.
belas
20
Sep 24, 2011 12:19 AM
mjtpolice76
Jul 10, 2010 08:48 PM
hhcobra
Jan 2, 2010 08:53 PM
Mydiesel250
Jun 21, 2008 06:59 PM
Trexx
Bronco II
Dec 8, 2003 03:12 PM
