White smoke....HELP
Old Sep 21, 2011 | 01:59 PM
belas's Avatar
belas
White smoke....HELP
Greatings, 2K F350 7.3 PSD and so on. Just had numbers 1 and 3 injectors replaced this year, new fuel filter this year, new glow plugs this year + solinoid. Truck gets to WOT, driving at 1500 rpm and looses power and shuts down. Hard to start afterwards with white smoke. Finally got it to the shop after driving 35mph and blowing white smoke and red lined. Been at the shop for more than a month. Mech said he doesn't want to tear it down without knowing whats wrong $$. Takeing it to Ford next week for diagnostic test for $90/hr. Any ideas what it could be?
Had trouble codes for Cam pos. sens. and EBP sens.
One more thing, when injectors where replaced, no o-rings on previous injectors.....any thoughts? Same mech. and I trust him.
Old Sep 21, 2011 | 02:23 PM
jc8825's Avatar
jc8825
CEL? What codes are stored? Get those and you will have a place to start.
Old Sep 21, 2011 | 02:36 PM
belas's Avatar
belas
My mech ran a code search and said it had no codes........Before i took it to him I got the codes from a superchips programmer.
Old Sep 21, 2011 | 02:40 PM
jc8825's Avatar
jc8825
You need specialized software to pull codes from a PSD. A standard code reader will show no codes. A diesel shop or diesel mechanic should have the correct software to pull the codes.
Old Sep 21, 2011 | 02:41 PM
belas's Avatar
belas
So, taking it to Ford is inevitable?
Should I try driving it less than 10 miles to Ford, or have it towed?
Old Sep 21, 2011 | 03:01 PM
jc8825's Avatar
jc8825
If you have to redline it to go 35, I would tow it. At least get Ford to diagnose it and take it to your mechanic to fix. Might be cheaper that way. I do know that for diesels, the diagnosis fee is double that of a gasser, so be prepared to spend at least $170 for that.
Old Sep 21, 2011 | 03:03 PM
jc8825's Avatar
jc8825
Keep us posted as to what the dealer finds and what it ends up costing you to have repaired.
Old Sep 21, 2011 | 04:56 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old Sep 21, 2011 | 05:22 PM
belas's Avatar
belas
Was told for my 7.3 it would be 90/hr. I guess I'll post again in a week, do you think I can fit a crew cab short bed on a car hauler? Length wise?
Old Sep 21, 2011 | 05:36 PM
timmyboy76's Avatar
timmyboy76
redline at 35mph, sounds to me, a trans/shifting issue. Can not remember what blue, white, black smoke means, but "search" and you'll find it
Old Sep 21, 2011 | 06:13 PM
jc8825's Avatar
jc8825
The labor rate is generally the same, but they charge 2 hours of labor for diesel diagnosis. As far as length, how long is the car hauler? Your truck is the second longest configuration. I would just call a tow company and tell them what you have and let them bring the right truck.
Old Sep 21, 2011 | 08:06 PM
dardick's Avatar
dardick
I had white smoke just before or during a hpop hose go.Check oil level as well when it gets low itll cause hard starts and white smoke.But my best guess is an oil pressure issue . Keep us updated .
Old Sep 21, 2011 | 09:10 PM
BigAlsPSD's Avatar
BigAlsPSD
I don't like the redline at 35mph either, but you could have restricted fuel pressure, possibly clogged screens in the tank. Have your mechanic check fuel pressure at the bowl.
Old Sep 22, 2011 | 12:39 PM
belas's Avatar
belas
Thanks to all, I'll keep you posted with results.
Old Sep 23, 2011 | 07:42 PM
medhvac's Avatar
medhvac
reminds me of the time my first injector went out while driving! so i put in a new one! then the second injector went out!then i replaced them all (new) no need to be broke down!
so any news yet?
