Starting Issues
Old Mar 18, 2014 | 09:35 PM
dc33cpsd's Avatar
dc33cpsd
Starting Issues
I have a 94 F-350, 7.3L, 5-speed Manual, VIN code K, Manufacture date 11/93 and the starter went out. I had replaced the starter with a Duralast starter part number DLG 5154, my problem is the fact that when I activate the starter, the gear does not touch the flywheel (I have my neighbor "attempt" to start the truck with me under it and flywheel cover removed). I have seen and followed the instructions in the posts on here about the same issue such as, checking and cleaning the connections, torqueing the bolts, checking and replacing the solenoid. Can someone help...?
Old Mar 18, 2014 | 09:45 PM
Cowboy9215's Avatar
Cowboy9215
May be wrong, never had this happen to me but sounds like you need a starter shim
Old Mar 18, 2014 | 09:52 PM
dc33cpsd's Avatar
dc33cpsd
Correct me if I am wrong, but wouldn't a shim push the starter further away?
Old Mar 19, 2014 | 07:44 AM
tjc transport's Avatar
tjc transport
i ain't rite
just because the starter has the proper part number on it does not mean it is the proper starter. if the drive does not engage the ring gear, you need to return it and get the rite one.
Old Mar 19, 2014 | 04:57 PM
dc33cpsd's Avatar
dc33cpsd
tjc transport,
Would you have information (Manufacturer's info and part numbers) on the proper starter?
Old Mar 19, 2014 | 05:09 PM
whiteboyslo's Avatar
whiteboyslo
According to AZ's website, DLG5154 is a Powerstroke starter, NOT an IDI starter: Gold Duralast/Starter (DLG5154) | 1995 Ford F250 3/4 ton P/U 2WD 8 Cylinders F 7.3L Turbo Diesel | AutoZone.com
You need PN 16561: Duralast Import/Starter (16561) | 1993 Ford F250 3/4 ton P/U 2WD 8 Cylinders C 7.3L Turbo Diesel | AutoZone.com
1994 is a funky model year. It was the LAST model year of the IDI and the FIRST model year of the Powerstroke, so you have to be super-careful when picking the right engine in any computer database system. To save confusion, from now on just tell them you have a 93 turbo diesel. Parts are identical to your 94.
Mike
Old Mar 19, 2014 | 05:16 PM
whiteboyslo
Wait, hold on. For giggles, I went into their system and made sure to choose EXACTLY the Year/Make/Model info you gave (I had to guess between 2WD and 4WD, but that doesn't matter).
A 1994 F350 VIN K shows DLG5154. Per this thread I found https://www.ford-trucks.com/forums/1...ine-codes.html, your VIN K is a turbo IDI. So, that means AZ's system is wrong. They have a Powerstroke starter listed for VIN K.
Mike
Old Mar 19, 2014 | 05:19 PM
dc33cpsd's Avatar
dc33cpsd
Thanks mike, I will give that a try... I have an IDI
DrZoom
16
Apr 6, 2016 11:42 AM
Funke1
Nov 26, 2015 08:54 AM
A H DEVELOPMENT
Jan 22, 2010 05:21 PM
fish-albuq
Dec 30, 2009 04:23 PM
1985f350
Sep 20, 2006 07:16 AM
