ICP Question
Old Mar 18, 2014 | 05:20 PM
Jerry Chaney's Avatar
Jerry Chaney
ICP Question
So I have these ICP codes, p1210, p1211, p1280, p1282. Looked up definitions, "ICP expected level", don't know what that means. "ICP not controllable, pressure above/desired", don't know what that means. "ICP circuit out of range", don't know what that means. "Excessive ICP", don't know what that means.
Also, p1209. "Injection Control System Pressure Peak", don't know what that means either. My truck is running good, but it is still loud as heck. Until I come to a stop sign or light, my idle go's down and seems like it's going to die. But it never does.
Old Mar 18, 2014 | 08:37 PM
white Buffalo's Avatar
white Buffalo
If you can, clear the codes and then see which ones return. 2nd - disconnect the ICP sensor and check to see if there is oil on top of the sensor - then try to start it with the sensor disconnected and see if it idles or runs better.
If it does run & idle better then replace the sensor.
With The ICP sensor disconnected the PCM (computer) goes off of a data table since it can not get e reading from the sensor. So if it runs better with it disconnected it usually means the sensor went bad.
Old Mar 18, 2014 | 10:20 PM
Jerry Chaney
I'll see if I can get ahold of A.E. and clear codes.
Tried disconnecting sensor awhile back ago, ran like ****.
thanks great white buffalo. I lived in Brookings for a few years, still have a brother that lives there.
Old Mar 19, 2014 | 04:33 AM
Tugly's Avatar
Tugly
Is your truck tuned in any way? Do you have modifications? Were you just scanning, or are you troubleshooting?
Those codes may have occurred some time ago, but if they pop back up - you'll need to do data logging to find out what's happening.
Old Mar 19, 2014 | 07:47 AM
Pikachu's Avatar
Pikachu
At the risk of sounding like Captain Obvious, also make sure the tin nut that holds the IPR solenoid in place hasn't fallen off . . .
Old Mar 19, 2014 | 01:00 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
P1280 is Circuit out of range. Meaning the sensor is bad. It could also mean the truck was on when the sensor was unplugged. Watch this video about P1280. When youre done, unplug the ICP sensor and see how your truck runs.
Old Mar 19, 2014 | 01:02 PM
Pikachu's Avatar
Pikachu
I've found some of the "out of range" codes after cranking with the batteries too low also. Clear the codes and see which ones come back.
Taylor815
17
May 19, 2017 09:32 PM
lstitt
Australia Chapter
Dec 22, 2015 02:43 AM
magum350
6.4L Power Stroke Diesel
Dec 22, 2012 11:00 AM
edub32
25
Feb 20, 2009 05:51 PM
robjs111
Jan 6, 2009 01:27 PM
