does anybody have the codes for 2008 6.4L and can you post them,my truck check engine lite just came on scaned and found P0106 I believe that has something to do with coolent temp but not sure.2008,F350,crew cab ,6.4L,34,800 milews.
P0106 X
Manifold Absolute
Pressure/BARO Sensor
Range/Performance
This diagnostic compares MAP and BP pessures at idle
conditions, when they should be within a specified range.
This error is set if the MAP sensor reading is above or
below the thresholds for a predetermined period of time.
N > function of (ECT)
Vehicle speed =0
ECT> 70 deg C
10% < EGRTP command <100%
no DPF regen requested
for > 10 seconds
300hPa or -300hPa >5sec
Wiring, MAP sensor, BP sensor
