Spark plug gap on 5.0
Old Mar 17, 2014 | 05:14 PM
bigdaddyII's Avatar
bigdaddyII
A few weeks ago I read a thread here about someone having his truck In to the dealer for a rough idle, and the ensuing issues with plug gap and who was responsible to cover replacement. My truck has a similar rough idle and I decided to investigate.
I asked here about what my plug gap was supposed to be as I didn't have access to my owners manual at the time. The specs I was given (.041-.047) is what I followed and recapped my plugs .045. The idle improved a great deal.
Now I was wondering and finally got around to checking my owners manual after I read somewhere that the gap for the 5.0 changed between 12 and 13 model years. What I found in my owners manual is that the gap I'm supposed to have is from .049-.053. My plugs were out anyway at .057. I will leave them be at .045 but am wondering why the change from .041-.047 on the 2011 model years to .049-.053 on the 2012+ model years? I assume the engine hasn't changed, so am curious of the thought process. TIA for any ideas.
Old Mar 17, 2014 | 06:15 PM
svt2205's Avatar
svt2205
I honestly think the .041 - .047 range listed in the owners guide is incorrect as my 2011 service manual shows .049 - .053
The plus I pulled at roughly 93K or so were in the .052 range and the one's I replaced them with were gapped at .051. And there was no change in idle smoothness or at any other engine speed.
Old Mar 17, 2014 | 06:22 PM
bigdaddyII's Avatar
bigdaddyII
I had 38.xxx on my plugs and they were all at .057. Weird.
Old Mar 17, 2014 | 06:36 PM
PrinceValium's Avatar
PrinceValium
Who knows if the gap was set right to begin with...but I am sure you know that as your plug wears your gap gets bigger from the electrode wearing down. (at least on most plugs)
Old Mar 17, 2014 | 06:48 PM
bigdaddyII's Avatar
bigdaddyII
I understand about the electrode wearing. But from .053 to .057 in 38,xxx miles? While I don't believe that they were gapped correctly to begin with. Why the sudden change from 2011 to 2012? I know of at least a few 2011 who specify the .041-.047 gaps so I know it was listed as such for a least a while in 2011. What's odd is that my truck seems to run better with the smaller, incorrect gap.
Old Mar 18, 2014 | 08:13 PM
bigdaddyII's Avatar
bigdaddyII
I replaced the plugs today with Bosch Iridiums. I know Bosch is typically a no no for spark plugs but that was all I could find. They were all gapped at .044, so I set them at .049 and slapped them in. Again I marvel at how easy it is to access the plugs on this engine with removal of anything, so if the Boschs give me any issue it won't be such a big deal to swap them back out. I was a bit nervous with the Motorcraft plugs after regapping and bending the electrode around on plugs that have already been through many heat cycles. Time will tell I guess.
Old Mar 23, 2014 | 11:47 AM
PrinceValium
I remember the days of the split fire plugs and how they advertised it gave better fuel burn etc.
I don't know if the Bosch will be in the right heat range for your truck...but hope they work for you.
Old Mar 23, 2014 | 04:48 PM
bigdaddyII's Avatar
bigdaddyII
Update to this. I only need them to work for 1 more day. I ended up getting nervous after reading about them a bit and ordered a set of Motorcraft. Unfortunately the reason I installed the Bosch in the first place is because that was absolute only ones available at a regular auto parts store. I just checked my order and its scheduled to be delivered to my work tomorrow, so after work tomorrow I will be installing those. $45 is worth peace of mind.
g_k50
1983 - 2012 Ranger & B-Series
Jul 1, 2015 02:49 PM
copperjohnc
Sep 28, 2011 11:02 PM
Owl
Apr 21, 2007 11:25 PM
AKranger
Aug 29, 2004 04:47 PM
