Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F600 Vin Decode
Old Mar 17, 2014 | 04:34 PM
Reddog80p's Avatar
Reddog80p
F600 Vin Decode
Hi guys,
Looking for some help decoding a vin for an F600.
Here's the info:
F600UW01032
194NF6024BBAF2K
Any info is appreciated.
Red
Old Mar 22, 2014 | 10:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F600UW01032 / W.B. 194 / COLOR: N / MODEL: F602 / BODY: 4B8 / TRANS: A / AXLE: F2K / MAX GVWR LBS: 19200
Welcome to FTE
F60 = F600 2WD (gas).
0 = No such VIN engine code as 0 or O / Could be a C = 330 2V M/D FT engine or D = 330 2V H/D FT engine.
U = Louisville KY Assembly Plant.
W01032 = 1975.
194" Wheelbase.
N = Exterior color N not listed until 1978.
F602 = F600 2WD (gas), 19,200 lbs. GVWR
4B8: 4B = Heavy Duty Black Vinyl / 8 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
F2K: F2 = Eaton model 15201 Two Speed Rear Axle / 5.83/8.12 / 15,000 lbs. Rear Axle Capacity // K = Ford 5,500 lbs. Capacity Front Axle with P/S.
19,200 lbs. Gross Vehicle Weight Rating.
Old Aug 30, 2018 | 05:41 PM
61FordBus's Avatar
61FordBus
Welcome to FTE
W01032 = 1975.
194" Wheelbase.
Hey ND,
Do you know if that “//K” code for the 5,500 front axle was used for the F600/F700 thru 1986?
That would really help my search....
thanks,
Robert S
Old Aug 30, 2018 | 08:01 PM
NumberDummy
Originally Posted by 61FordBus
Hey ND,
1980/89 600 and larger series trucks front axle codes:
Old May 19, 2026 | 12:34 PM
Schmdthappns's Avatar
Schmdthappns
1st Gear
F600 vin
Been awhile since anyone posted to this thread but need help with a vin the build sheet from a seat I'm looking at says 12/20/1983 but sheet only had 11 digit vin F60EVA21285 looking for insight on year
Old May 20, 2026 | 06:03 PM
asavage's Avatar
asavage
FTE Community Team
That looks to be a Truck Specifications List (TSL).
F60EVA21285
F60 = F600
E =
* if 1967: 361 2v
* if 1976: 361 2V XD OR 391 4V XD
V = Kentucky plant
A21285 indicates build month Aug1966 (1967 model year) OR Aug1975 (1976 model year) (ref.)
Maybe it's a reprinted TSL sheet? 1981+ should have a 17-character VIN, if it was sold in the US/Canada.
[later]
Well, it resembles a TSL. I looked at the TSL for '67-90 and with minor variations they all look like this:
Hopefully, someone with more knowledge will come along and educate us.
Old May 20, 2026 | 09:13 PM
85e150's Avatar
85e150
Kentucky Truck Plant opened in '69 so it has to be a '76.
Old May 20, 2026 | 11:05 PM
asavage's Avatar
asavage
FTE Community Team
The form is marked as being printed Nov '83, and the print date is Dec '83. Hmmm.
4BDiesel
Large Truck
Feb 24, 2019 06:18 PM
Neafarmer
Large Truck
May 26, 2018 12:56 PM
Gary38532
Large Truck
Dec 3, 2017 08:43 PM
TaylorDiabetoSwifty
Large Truck
Mar 20, 2017 12:51 PM
Matthewearlmalone
Large Truck
Feb 24, 2016 09:25 AM
