I was wondering if you could give me the full vin break down kinda curious what the original color was
F60 = F600 2WD
D = 330 2V H/D FT engine.
V = Kentucky Truck Assembly Plant.
Q63297 = 1973.
176" Wheelbase.
M = Wimbledon White.
F602 = F600 2WD; 19,200 lbs. GVWR
4 8: 4 = Black all Vinyl / 8 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
F32:
F3 = Eaton model 15201 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity.
2 = Ford 5,500 lbs. Capacity Front Axle.
19,200 lbs. Gross Vehicle Weight Rating.
DSO code (Ford city/state district sales office the truck was ordered from) is missing, which is very odd, as all FoMoCo vehicles Warranty Plates have it.
Whoever at the factory that stamped this plate, must have "fallen asleep at the switch," or went to lunch or it was quitting time.
