1974 f-600 vin decode
Hi all this is my first post have been through so many post I thought might as well join. Any ways I have a f600 dump truck just looking for the info of my vin tag any help is appreciated.
Vin F60evt20722
Wheelbase194
color t
Type F602
Body4B8
Trans9
Axle f32
9200
521596
Vin F60evt20722
Wheelbase194
color t
Type F602
Body4B8
Trans9
Axle f32
9200
521596
v.i.n. code
I am new at this, if I screw up someone will let you know!
f-60: f600---2/w/d and gas
e: gas, 8cyl.,361 c.i.d., 2b
v: kentucky truck plant
t20722: 1974
w.b.: self explaining
t: sorry not smart enough to find
f602: 73/79 19,200 g.v.w. f600---2/w/d and gas
4b8: standard cab
9: either a 15spd.fuller or more likely a new process: 5spd.,np542fd
f-3: 6.33/8.81 15m eaton 15201 2 speed
2: (third digit of axle code) 5.5m ford 5500 w/o per. steering
I hope this will get you by until someone can fill in blanks and/or correct my mistakes
t20722: 1974
4b8: standard cab
E = 361 2V or 4V FT engine.
V = Kentucky Truck Assembly Plant.
T20722 = 1974.
184" Wheelbase.
T = Red.
F602 = F600 2WD (gas); 19,200 lbs. GVWR
4B8: 4B = Black all Vinyl / 8 = 81A Standard Cab.
9 = New Process 542-FD 5 Speed Direct.
F32:
F3 = Eaton model 15201 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity.
2 = Ford 5,500 lbs. Capacity Front Axle without P/S
19,200 lbs. Gross Vehicle Weight Rating.
521596:
52 = Dallas TX Ford District Sales Office, where the original selling dealer ordered the truck from.
1596 = Domestic Special Order number. Truck ordered special by original purchaser, not "bought off the lot."
