F600 Vin Decode
Hi guys,
Looking for some help decoding a vin for an F600. Here's the info: F600UW01032 194NF6024BBAF2K Any info is appreciated. Red |
Originally Posted by Reddog80p
(Post 14172981)
F600UW01032 / W.B. 194 / COLOR: N :-huh / MODEL: F602 / BODY: 4B8 / TRANS: A / AXLE: F2K / MAX GVWR LBS: 19200 F60 = F600 2WD (gas). 0 = No such VIN engine code as 0 or O / Could be a C = 330 2V M/D FT engine or D = 330 2V H/D FT engine. U = Louisville KY Assembly Plant. W01032 = 1975. 194" Wheelbase. N = Exterior color N not listed until 1978. F602 = F600 2WD (gas), 19,200 lbs. GVWR 4B8: 4B = Heavy Duty Black Vinyl / 8 = 81A Standard Cab. A = New Process 435 4 Speed Manual Transmission. F2K: F2 = Eaton model 15201 Two Speed Rear Axle / 5.83/8.12 / 15,000 lbs. Rear Axle Capacity // K = Ford 5,500 lbs. Capacity Front Axle with P/S. 19,200 lbs. Gross Vehicle Weight Rating. |
(Post 14189689)
Welcome to FTE
F60 = F600 2WD (gas). 0 = No such VIN engine code as 0 or O / Could be a C = 330 2V M/D FT engine or D = 330 2V H/D FT engine. U = Louisville KY Assembly Plant. W01032 = 1975. 194" Wheelbase. N = Exterior color N not listed until 1978. F602 = F600 2WD (gas), 19,200 lbs. GVWR 4B8: 4B = Heavy Duty Black Vinyl / 8 = 81A Standard Cab. A = New Process 435 4 Speed Manual Transmission. F2K: F2 = Eaton model 15201 Two Speed Rear Axle / 5.83/8.12 / 15,000 lbs. Rear Axle Capacity // K = Ford 5,500 lbs. Capacity Front Axle with P/S. 19,200 lbs. Gross Vehicle Weight Rating. Do you know if that “//K” code for the 5,500 front axle was used for the F600/F700 thru 1986? That would really help my search.... thanks, Robert S |
Originally Posted by 61FordBus
(Post 18168688)
Hey ND, Do you know if that “//K” code for the 5,500 front axle was used for the F600/F700 thru 1986? https://cimg6.ibsrv.net/gimg/www.for...a997074acf.jpg https://cimg2.ibsrv.net/gimg/www.for...861ede014c.jpg |
