How do i check my oil pressure sender and gauge
Hi i have fitted a new oil pressure sender and switch but its reading 80+ i am getting oil in the rocker cover so i am not sure if its a faulty switch.This is on my 223 engine.I am learning as i go along so it will be new for me to check.Thanks a ride out in her
Here is a good diagram of the oil pressure gauge circuit. I would check to see if you have any voltage at the sender. If not follow the wire back to see if there is a break somewhere. If there is voltage just quickly ground the wire to see if the gauge moves. If it moves the gauge should be OK so the sender may be your culprit. If it doesn't then you may have a bad gauge. It usually is the sender.
Big E and Old Yeller
05-05-2005 12:35 AM
Gobstopper909
06-03-2004 08:53 PM
