Scratching my head. Ideas?
Old Mar 16, 2014 | 11:04 PM
  #31
04badford's Avatar
04badford
Originally Posted by 1NiceHarley
The connector and sensor looks good.?.? Worth buying a new sensor and installing it or since it's going one wait and see what happens.
Is the Truck running when you are doing a Wiggle test to the ICP wires ?
pinch ,wiggle pull, push them around and see if the truck acts up.
Old Mar 17, 2014 | 10:23 PM
  #32
1NiceHarley's Avatar
1NiceHarley
I drove the Excursion today. No issues. While it was running I wiggled/pulled/moved the wires and sensor, no change in the way she ran. I did notice while I was cranking her to start that my IPR was ~ 33, ICP ~ 1200 but my ICV was .23 ( or something close. Then when it started the ICV went .7+ real quick.
I'm thinking I need a new sensor. Thoughts????
Old Mar 17, 2014 | 10:36 PM
  #33
04badford's Avatar
04badford
Normal IPR Values
koeo =14.84 low= 24 high2500 rpm =40.60
The ICP needs 540 psi to start anything lower might be the sensor
the ICPV at koeo=0.2 low=1.0 high=1.5 if ICPV is bouncing around and getting wack values there is a short or wire chaff .
Old Mar 18, 2014 | 07:16 PM
  #34
1NiceHarley
I found a new international ICP sensor and pigtail shipped for $100 on EBay so I am just going to replace both. Cheap enough to try. I'll keep you updated on the outcome. Thank you for all the help.
Gibsonjork
May 8, 2013 09:36 AM
ewellman
Sep 6, 2012 03:00 PM
fullthrottle9393
Jan 6, 2010 08:02 AM
c-bolt
Mar 5, 2007 11:36 PM
