2006 Something is wrong?
Old Jan 5, 2010 | 11:17 PM
fullthrottle9393's Avatar
fullthrottle9393
Hi I have a 2006 ford with the 6.0 in it. I had noticed it was'nt starting up on the first turn, i had to warm the plugs up a couple of times. I decided to take it to a local shop to get it checked out. They said that there were two injectors that were bad and that was the problem with it not starting right. I had them change the two and when i went to pick it up i tried to start it and it would not start for me. It was cranking and wanted to go but just woulden't. I gave them back the keys as i had to get going to my job. I stopped back by the next day and they said after i left it started right up, they let it idle for about 30min and it had died. They started it back up and it seemed fine i think they said they flashed the computer and put a new program on it. The next morning they started it up and put about 20 miles on it, everything seemed fine. I came and got it and drove it home, it drove home just fine, a couple of days later i had to help a friend move a few things. I started the truck up to let it warm up and let it idle for about 30min it had died on me, i started it back up but it was alittle harder to get it started. I took off to go meet my friend and it drove good, then it just started feeling like it wasn't getting fuel and then it just died on me. I sat and kept trying to start it and then finally it it gathered itself and started up, ran fine again. By the time i was done helping my buddy it had died on me 5 times, each time when i tried to start it it did not just pop right off, it would slowly start to rev up and then when i got the rpm's up it seemed to come out of the boggyness and it would run fine until the next time it started to lose power. I was wondering if anybody would know what this might be
any info would be greatly appreciated
Old Jan 6, 2010 | 07:20 AM
bismic's Avatar
bismic
Lots of similar threads. Start by reading the one below:
https://www.ford-trucks.com/forums/9...-6oh-info.html
After reading through the thread, let us know what else you need.
Old Jan 6, 2010 | 07:27 AM
jdw1's Avatar
jdw1
I would have the FICM checked.
Old Jan 6, 2010 | 08:02 AM
9228.bobcat's Avatar
9228.bobcat
Check fuel pressure as well. Maybe fuel filters, fuel pump. If you have good pressure at least you can rule them out.
mattri
13
Jun 20, 2014 09:34 PM
DeRooster3785
Nov 30, 2013 10:48 PM
IDAH0.REDNECK
Feb 8, 2013 10:47 AM
jlager
Nov 14, 2012 09:54 AM
KPMariner05
Jul 25, 2007 05:38 PM
