Keys locked in
Old Mar 14, 2014 | 07:05 PM
TektonB's Avatar
TektonB
Keys locked in
Locked keys in my 1979 ford and can't find extra set. Brand new paint job too and live way out in the country. Any easy way to get in? Hoping I can remove the slider window somehow to get in. Can't get in through the vent windows because they are locked tightly in place. I know, it's embarrassing. I can do it the old fashion way, but don’t want to hurt the paint on the door.
Old Mar 14, 2014 | 07:09 PM
Dave145's Avatar
Dave145
Is your slider old? I get into my truck by sticking a flathead screwdriver (large one) between the center strips, then taking a smaller flathead screwdriver, placing it on the latch, and whacking it with my hand to pop the latch open.
Old Mar 14, 2014 | 07:17 PM
TektonB's Avatar
TektonB
I've tried something similar, but it seemed to put a ton of pressure on the slider and I don't want it to break. But, I've got few options at the moment and i'll give the flatheads a shot. Thanks!
Old Mar 14, 2014 | 07:18 PM
TektonB's Avatar
TektonB
Now I wish I hadn't fused the vent windows . . . .
But I live in a vehicle theft prone community and my truck is flashy.
Old Mar 14, 2014 | 07:53 PM
Dave145's Avatar
Dave145
Sucks living in a place where ya gotta lock your truck...hell mine is always unlocked...then again, ya can't really steal it because if starting it doesn't wake the dead, its exhaust sure will!
On the other note...good luck getting in. My backup plan is to punch through my rusted out floorboard if I'm really in a jam...
Old Mar 14, 2014 | 08:21 PM
Jklnhyd's Avatar
Jklnhyd
Doesnt autozone or those stores, sell slim jims? You can probably google how to make and use one.
Old Mar 14, 2014 | 08:31 PM
GLR's Avatar
GLR
Sometimes local law enforcement will help.
Old Mar 14, 2014 | 09:00 PM
hickory1991's Avatar
hickory1991
I've gotten into many old vehicles with a coat hanger bent just the right way to lift the door lock button.
Old Mar 15, 2014 | 01:57 AM
Ordnance's Avatar
Ordnance
Take a shoelace, Tie a small loop in the middle. Hook the lace on the inside of the door, use a sawing motion back and forth until the lace works itself inside. Hook the door lock on the loop, and then twist the shoelace until the loop is tight around the door lock. Pull straight up.
Video for those visual learners
Old Mar 15, 2014 | 08:45 AM
4x4slik's Avatar
4x4slik
Don't think the shoelace will work because of the way the doors are set in. I have broken into these trucks with a pocket knife and once with 2 spoons, but I did it for a living for 18 years so had a little experience. Coat hanger is best bet. One way ould be to bend it into a U shape and try to catch the bottom of the lock ****.
Old Mar 15, 2014 | 10:13 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Put some masking tape/blue tape on the cab and door edge and wrap the coat hanger to protect the paint.
Once you are in, go get a door only copy made and wire it on the truck in some hidden place......
Old Mar 15, 2014 | 11:03 AM
HIO Silver's Avatar
HIO Silver
Make a Slim Jim like pictured below. Mine is stainless steel and 24 inch long by 1.25 inches wide. The notches are .75 x .375.
Insert and drag it along the back side of the door to catch the latch rod and pop'er open.
So easy a caveman can do it... which is kinda scary IMO.
Old Mar 15, 2014 | 04:20 PM
FEMAN78's Avatar
FEMAN78
take the clip that holds the cap on the mastercylinder and its bent just right to fish thru the wing window and turn the latch, unless you have the ones with the button.
Old Mar 15, 2014 | 06:10 PM
HIO Silver's Avatar
HIO Silver
Amaze your friends with an expanded vocabulary!
It's called a "bail" -i.e. "master cylinder reservoir cap/cover bail".
Old Mar 15, 2014 | 11:52 PM
smokenchoken's Avatar
smokenchoken
i used a butter knife to get into mine once or twice through the wing vent..... also if you have any buddies with 67-79 (possibly newer) ford trucks ask to borrow their keys for just a moment..... i have a stack of ford keys i keep for just such an occasion and about 80% of the time i have the right key.... somewhere.....
ola1234
Apr 28, 2016 06:51 AM
Mr7.50headsup
29
Jan 12, 2014 12:03 PM
TexasGuy001
Dec 8, 2011 05:20 PM
Nightrain
Paint & Bodywork
Oct 12, 2004 02:49 AM
Greg 79 f150
May 2, 2004 04:17 PM
