Door window assemble
Old Apr 25, 2016 | 12:43 AM
ola1234's Avatar
ola1234
I just got my truck back home from the paintshop. Have got most of the parts. Just have to get New Wood for the bed. It is kind of scary to assemble a truck With fresh Paint, and I have to do Things the right way to avoid scratches. Do anyone have a "step-by-step" how to assemble vent-window, window, the rubber absolutely everything is out. What have to be done first, second and so on....
Old Apr 25, 2016 | 08:44 AM
vtpkrat2's Avatar
vtpkrat2
`I do not have a step by step but I would say this. Anywhere you are worried about scratching the paint, mask it off with masking tape. If your paint has cured for more than a couple days you should have no trouble with removing the tape. Generally with any door assembly a person would start with largest parts, as in the glass itself. Then regulator,(although sometimes regulator first in some rigs),tracks,vent&track,moldings,rubbers,door panel,handles/cranks.. Quite a bit of room in these doors so once you get going you should be fine. Maybe a bit of trial and error for you but you can do it. Gary
Old Apr 25, 2016 | 08:49 AM
lafermedavid's Avatar
lafermedavid
You Tube precision restoration ,they have some good vids on door glass,and I believe Bronco graveyard are selling their product as well
Old Apr 25, 2016 | 08:01 PM
tndallas's Avatar
tndallas
That vid at the first shows a little how to do it. Put more tape than what they show. Down in the door channel and on the vent itself. Especially on that mounting point.
Insert the mounting point into the channel. There's a little gap near where the vent ends up. Then rotate and push up. I'd put tape all up and down the metal. It's real easy to scratch as it goes in.
Old Apr 25, 2016 | 08:46 PM
lxlmariuslxl's Avatar
lxlmariuslxl
If the paint is newer than 3 weeks I would be very careful about taping up the body. New paint does run the chance of pulling up with tape if not done correctly!! And why don't we have any pictures?!? Everyone loves freshly painted dents!!
Old Apr 28, 2016 | 06:51 AM
ola1234's Avatar
ola1234
Thank you for replies. So you want Pictures? Lot of work left, but here are some....
Original color; Dark Nectarine
RobertJohn
18
Jan 6, 2015 07:10 AM
superman64011
Sep 9, 2010 08:40 PM
rmallow77
Oct 14, 2008 02:42 PM
badgerbrock
Jan 31, 2008 08:49 AM
rumblinbass
Apr 25, 2002 10:37 AM
