ball joint how to
Old Mar 13, 2014 | 02:05 PM
Jarryd's Avatar
Jarryd
ball joint how to
Anybody have a write up on this job on a 2x4 f150?
Wondering how far I have to take it apart.
Wondering if I can just disconnect the tie rod and press them in one at a time.
Old Mar 13, 2014 | 06:44 PM
95F350XL's Avatar
95F350XL
You have to take the spindle out and press both out at the same time, lower 1 1st, then upper. Then install upper 1st and then lower.
Old Mar 13, 2014 | 07:51 PM
Jarryd's Avatar
Jarryd
Sounds easy enough. Hoping I can get this done fairly quickly.
Old Mar 13, 2014 | 09:17 PM
blkF250HD's Avatar
blkF250HD
Pick up a manual, and make sure you have a torque wrench. Also borrow/rent/buy a ball joint press. It's important the ball joints get torqued to the correct spec in the correct order, or you may get memory steer. Also remember how the camber bushing was installed.
Old Mar 13, 2014 | 09:23 PM
Jarryd's Avatar
Jarryd
Lol. I have all that. I'm not new to turning wrenches, just fairly new to these trucks. I've been building mustangs for 10 years but only been messing with trucks for a year.
Old Mar 13, 2014 | 09:43 PM
blkF250HD's Avatar
blkF250HD
It shouldnt be too bad being a 2wd F150. It took me ~9-10 hrs to do all 4 ball joints, pads, and rotors on my 4wd F250 with hand tools only. Bent two ball joint presses (big matco ratchet!) in the process. They were in tight!
Old Mar 13, 2014 | 10:19 PM
Jarryd's Avatar
Jarryd
I hope it doesn't take that long. I have some experience and know how it all should go together so it shouldn't be too bad.
Old Mar 14, 2014 | 08:38 AM
tjc transport's Avatar
tjc transport
i ain't rite
plan on a two day job.
i did a 91 last year, the passenger side took 6 hours because everything was seized except for the ball joint sockets. they fell apart..
next day the driver side two 2 hours because everything came apart with no problems..
plan on replacing the tie rod ends while you have it apart.
Old Mar 14, 2014 | 08:40 AM
Jarryd's Avatar
Jarryd
I was hoping I wouldn't have to do that. I have air tools so it shouldn't be hard to get everything apart.
Old Mar 14, 2014 | 09:11 AM
tjc transport
i ain't rite
i have air tools, presses, and just about everything else too.
i ended up having to use an air chisel to drive the passenger side camber bushing out after heating it up with the torches, and then had to use a 5 lb sledge to beat the spindle/ balljoints out of the axle after heating them up.
the driver side fell out after unbolting it.
Old Mar 14, 2014 | 09:17 AM
Jarryd's Avatar
Jarryd
I recently had a front end alignment so it was apart about 6 months ago. That's probably to my benefit.
clhart426
18
Jan 19, 2021 09:46 AM
mgmoore7
Sep 18, 2016 09:00 PM
sum_weirdo
Apr 26, 2011 10:28 AM
somelus
Oct 16, 2003 04:43 PM
agillings
Oct 26, 2000 12:40 PM
