U Bolt Question
Old Mar 13, 2014 | 08:59 AM
RobRoss's Avatar
RobRoss
U Bolt Question
Lets say your suspension is upgraded (V's/Modded B's or some other combination) and you're not happy with the ride height. If you try adding subtracting shims, leaves etc, are folks replacing U bolts everytime? I'd guess no but thoght I'd ask.
Old Mar 13, 2014 | 10:23 AM
robert_l_ross's Avatar
robert_l_ross
Per Ford the bolts are to be used once, but many on the forum have re-used them. I personally follow Ford's advice, but that's just me.
Old Mar 13, 2014 | 01:21 PM
golfmedik's Avatar
golfmedik
I bought new ones when i did the swap, and new ones again for the rear when I leveled it out with the F350 blocks.
Old Mar 13, 2014 | 01:23 PM
robert_l_ross
Good thing is if you do decide to get them, you can have them made by a local suspension shop for cheap...I think mine ran in the ballpark of $10-12 per for the fronts, $14 or so per for the rears.
Old Mar 13, 2014 | 02:17 PM
00X7.3PSD's Avatar
00X7.3PSD
I agree and it is the correct thing to do.
I can think of 2 reasons why ford don't want people to re-use ubolts.
1) Liability- Someone might use ubolts that is in poor condition.
2) Profit- Can't sell new ones if people re-use them.
Personally, I would re-use ubolts if they are undamaged. When you're happy with your setup, then use new ubolts if that will give you peace of mind.
I bought new ubolts for my B mod, but I end up using old ones. I'm saving new ones for my permanent setup.
Old Mar 13, 2014 | 06:11 PM
WE3ZS's Avatar
WE3ZS
I had new U-bolts made at a local spring shop when I first did my spring swap. The initial setup didn't put the rear lift where I wanted it so I took it all apart and added a few bits to the mix and then I reused the U-bolts. Almost 20k miles of towing heavy (9.5-10.5k lbs) and they are doing fine.
Does anyone else find it interesting that in this post (and others) we have a "Robert L. Ross" discussing the issue with a "RobbRoss" ? .........
Pretty cool I think, gotta love the interwebs!
Old Mar 13, 2014 | 07:03 PM
Stewart_H's Avatar
Stewart_H
Yes, that tickled my amusement bone when I first saw that RobbRoss had registered here.
Stewart
Old Mar 13, 2014 | 09:42 PM
robert_l_ross
It's actually me...I'm chatting it up with my 2nd evil head. BWAAAHAAHAAAA!!!
Old Mar 13, 2014 | 11:45 PM
wpnaes's Avatar
wpnaes
I bet that Evil head says re-use those U-bolts, while the Saintly head says 'No way Jose'...
Old Mar 14, 2014 | 12:48 AM
Stewart_H's Avatar
Stewart_H
Not for nothing, and I know it's wrong, but I reused my U-bolts up front, and I got a set of take-offs from a local 4x4 shop for the rear when I did my spring swap. That was 8 years ago and over 100k miles.
Stewart
Old Mar 14, 2014 | 03:30 AM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Honestly I think it boils down more to how the vehicle is used and the overall condition, longevity of install, etc. Personally, I have re-used u-bolts twice. Once on my Jeep, had them on for a few months and many trail rides. Took them off to revamp the rear springs, threw them back on, and the passenger side failed while on the trail. I chalk that up to vehicle use and abuse.
Second time was on my Ex, realized I neglected to install the Ex shims while doing the B mod, so I pulled it apart and re-used the u-bolts. They were new, maybe two weeks old so I felt confident in their integrity.
Other than that, absolutely no way - new u-bolts every time. Just like strap bolts on the yokes for driveshafts - I throw new bolts in every time. In the end its relatively cheap insurance. Bolts get torqued and they stretch minute amounts, never know when one is going to fail under load and seriously mess up your day.
Old Mar 14, 2014 | 08:53 AM
RobRoss's Avatar
RobRoss
Thanks for the input guys!
Old Mar 14, 2014 | 11:47 AM
JKTex's Avatar
JKTex
I reused mine on the front. I think I did the swap 5-6 years ago.
DieselHardware
Mar 1, 2018 11:19 AM
Pastor Scott
Apr 14, 2017 09:17 PM
dclowrider
Dec 8, 2013 11:36 AM
759dad
Feb 16, 2011 11:11 AM
jacque_strap
1978 - 1996 Big Bronco
Oct 13, 2004 06:21 PM
