Sponsored by: Real Truck
Rear U bolts question
Old Apr 14, 2017 | 05:24 PM
Pastor Scott's Avatar
Pastor Scott
I added a 1inch lift block to my 2008 f250 4x4 rear...my concern is the nuts which had the bolt threads sticking through about an inch.. not they are flush...is that a concern.. should i get new longer u bolts and if so where would I c=get them
thanks guys
Ps Scott
Old Apr 14, 2017 | 05:26 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Generally you want at least two or three threads past the nut, and your not really suppose to reuse ubolts. they are one time use because they stretch when first torqued
Old Apr 14, 2017 | 05:30 PM
Tedster9's Avatar
Tedster9
Want at least a few threads past the nut. "Technically" U-bolts are not to be reused, they are rolled threads, not cut. Any truck shop or spring shop, somebody local to you can make them while you wait. Bring an old one along so they can match width and determine round or half round, square etc.
Old Apr 14, 2017 | 05:39 PM
Pastor Scott
Where do I get new ones that are a little bit longer ..
Old Apr 14, 2017 | 06:06 PM
SuperDutyScaler
http://www.pmfsuspension.com
http://www.oneupoffroad.com
or any local spring shop in your area
Old Apr 14, 2017 | 09:17 PM
Pastor Scott
Thanks...ordered and on their way...You guys are the best
1978fordf250
Offroad & 4x4
Jun 12, 2008 06:20 PM
HTTTRH
Jan 25, 2008 01:30 PM
cowboyty
Mar 24, 2007 07:09 AM
microb
Feb 9, 2007 08:10 AM
DS02F250
Dec 17, 2004 10:10 PM
