HANDLE REMOVAL
Old Mar 12, 2014 | 09:22 AM
jason7482's Avatar
jason7482
HANDLE REMOVAL
What is the best way to remove window and door handles? Driverside fell right off but pass side hasnt i have taken set screw off and pry on it and nothing. Am i missing a step? Thanks
Old Mar 12, 2014 | 09:50 AM
schoo's Avatar
schoo
I have seen them glued with jb weld, corrosion on them that made like glue
Maybe a little heat will help
Old Mar 12, 2014 | 11:21 AM
daveengelson's Avatar
daveengelson
As Schoo mentioned, heard of owners using JB weld, or something similar, to attach handle to the shaft when the gear is worn, and I will refrain from making any derogatory comments when an owner does as not to offend any FTE member. Not sure what to do if the handle is glued to the shaft. Otherwise, suggest try giving the shaft and set screw area a shot of penetrating oil and let it set over night. If believe the shaft and handle is seized due to rust then suggest trying a mild solution of rust converter, would not let set too long. I would apply, let set few minutes, then flush, if there's a heavy rust color then repeat couple times?? If turns out it is JB weld, or similar the only way to remove is using high heat, over 600 degrees?
Old Mar 12, 2014 | 01:10 PM
TxStang2010's Avatar
TxStang2010
I had one of mine stuck and it was corrosion that had it firmly in place , I used my tie rod joint separator to put even pressure behind it and heated it up with my heat gun and after about 2 minutes of applying medium heat it popped right off
Old Mar 12, 2014 | 10:22 PM
ras4434's Avatar
ras4434
I took an extra door handle (doesnt everyone have a few laying around), took the screw out. I put the handle on and had a friend push it in as far as possible. I then took an extra long drill bit (home depot for $3) and drilled into the handle spline. Enough to set the handle screw into. Put the good handle on pushed it in all the way and tightened the screw. All is right with the world...well at least it hasn't come off.
jnd1959
Mar 28, 2026 09:31 AM
RickTFL
Apr 29, 2014 12:14 AM
jack orchard
Nov 5, 2013 02:46 PM
sdeforest
1997 - 2003 F150
Apr 4, 2007 09:41 PM
77fromheaven
Jun 14, 2002 10:37 PM
