frozen U-joint removal
Old Jun 12, 2002 | 10:34 PM
77fromheaven's Avatar
77fromheaven
i bought an axleshaft the other day from my new favorite junkyard, and it has a U-joint frozen in it. I've been soaking it in old oil for close to a week now, and it's still stuck one way, but rotates the other. I cannot figure out how to loosen it up and get it out. I can't even get the retaining clip to come off (rust rust rust). has anyone encountered this and conquered it? I am lost. Please Help!
Thanks for any hints or tricks.
Old Jun 13, 2002 | 03:50 PM
dfisher1's Avatar
dfisher1
Dear Mr. 77,
Your in trouble! Wash the shaft of and remove all oil that you can. Get a torch and try the seized bolt method. Heat it up red hot and see if you can knock it loose with a hammer. Heat the U-joint cap not the shaft. Don't burn a hole in it yet. Save that for the ultimate disaster.
Another crazy idea is to soak it in Coke. The ascorbic acid may do a number on it. I've used Coke to get rust out of gas tanks. I think this is a whole lot different though.
PB Blaster is a great penetrating oil and would work better than oil any day.
In Summary, a hammer is your best friend now.
My Way is the Highway,
KingFisher
Old Jun 13, 2002 | 08:11 PM
77fromheaven
Oh Boy! Sounds like a good time. I made arrangements with my neighbor to use his torch. I'll go ahead and buy some PB Blaster....put me on the "not a happy camper" list.
Thanks a lot! I'll let you know how bad it is
Old Jun 13, 2002 | 09:20 PM
Jimbare's Avatar
Jimbare
all alone in the world
watch that torch trick!!!! if the joint has any grease or oil in it, it may explode!!!! since the joint is frozen you may be safe, but be carefull! i have seen many worn out joints shoot a cap at you when heated.
Old Jun 13, 2002 | 11:38 PM
highcountry's Avatar
highcountry
[updated:LAST EDITED ON 14-Jun-02 AT 00:41 AM (EST)]Just a thought but have you tried a u-joint press? Available at your local parts store and worth every penny. I haven't encountered a u-joint to tough yet. Also the best penitarting oil I have ever used was a ford brand. It is black and foamy and it WORKS. The parts guy handed it to me one day and I have been hooked ever since. If you want I will look at the part number while I am in the shop tomorrow. Hope that helps.
Old Jun 14, 2002 | 01:41 PM
77fromheaven
Ya, please check that number on the ford penetrator. I'm going to autozone right now, i'll check on the press. Thanks a lot!
Old Jun 14, 2002 | 09:15 PM
Bronco894x4's Avatar
Bronco894x4
If you are near a Northern Tool Company, they have 12,000 lb. shop presses for sale for $99.99. I picked up one from a tool center in a flea market for $79.00 and it has been worth every penny of it. It saves alot of time.
Bronco894x4
Old Jun 14, 2002 | 10:21 PM
highcountry
My can of penetrating fluid seems to have wandered off. Sorry about that. I hope that I can find it because I really wanted more when that can ran out. I will look around some more. If I find it I will post it. If you use any penetrating fluid it should work. This stuff was good because it was thick and would hang on instead of just dripping. You could always go to the store with a can and try all thiers untill they catch you and get mad. Like I said the reason this stuff worked so well is that you could put it on and it was thick and foamy instead of liquid like most. Sorry about the missing number. Good luck!
Old Jun 14, 2002 | 10:37 PM
rick's Avatar
rick
fordsinair
2004 - 2008 F150
26
Aug 13, 2015 12:41 PM
polarisman
May 28, 2015 12:27 PM
Ford SD
Mar 31, 2015 03:05 PM
Argess
Sep 20, 2012 06:18 PM
preppypyro
Dec 6, 2009 05:40 PM
