Very stuck U Joints
Old Nov 27, 2009 | 10:46 PM
jnd1959's Avatar
jnd1959
Very stuck U Joints
Trying to get the old u joints out of the shaft and yoke. I've tried c clamps, hammer with drift and soaking them for days, even tried cutting them with a sawzall (that was a duh moment). No movement at all. This is on the 88 F250 frame I am working on. The retaining rings are out. Is there something else there i am not aware of? If not, has anyone tried to heating the yoke with a torch? Ideas are always appreciated.
Old Nov 27, 2009 | 11:20 PM
Danspeed1's Avatar
Danspeed1
I was just there two days ago! Just keep at them -or- take the driveshaft over to a machine shop and have them pressed out. As long as the clips are out the u-joints should come out. Mine were so rusted in it took two days of PB Blaster, Heat from a torch, hammering and finally pressing to get them out; but I did.
I also had a similar "duh moment." When I could not get the new u-joints from binding when they were pressed in (because of all the rust in the bores), I decided to hone out the interior diameter of the shaft bore. Unfortunately I went a little over board, took off too much metal, and now I have my caps rotating in the bore... not a good situation!
When you clean them up be careful... if you want to clean out the bores i advise nothing harsher than sand paper and very little sanding.
Good luck,
Dan
Old Nov 27, 2009 | 11:36 PM
86bigred's Avatar
86bigred
i use this tool to get u-joints out with an impact wrench it works.when i did my front u-joints they were siezed in there to but this tool got them out whit a load bang.
if you are going to clean up the rust inside the yokes i use a dremel tool with a sand paper flapper wheel,removes rust not much metal. IMO
Old Nov 28, 2009 | 12:51 AM
Danspeed1's Avatar
Danspeed1
Yea be careful with the dremel though. That's what I used with a very high grit polishing stone, and I still managed to remove enough metal that my caps are loose. If I had to do it again I would do it with sand paper by hand.
Just my $0.02
DG
Old Nov 28, 2009 | 08:27 AM
bashby's Avatar
bashby
Careful with that ball joint press there, bigred, I've bent the ears on the driveshaft with mine a couple times
Old Nov 28, 2009 | 08:45 AM
jnd1959's Avatar
jnd1959
Thanks to all. I'll keep plugging away.
Old Nov 28, 2009 | 11:43 AM
86bigred's Avatar
86bigred
Just my $0.02
DG
thats why i said use the flapper wheel.it will remove the rust and not the metal.
Old Nov 28, 2009 | 11:45 AM
86bigred's Avatar
86bigred
thanks i''l keep that in mind
Old Nov 28, 2009 | 08:31 PM
Franklin2's Avatar
Franklin2
I've bent them with a press too. You will know they are bent a little bit when you don't seem to have room for the clips to go back in.
Old Nov 28, 2009 | 09:40 PM
jnd1959's Avatar
jnd1959
Well. I finally got to that place i usually get to wherre I don't care if I bend or break something, I just want it finished. So I took a gear puller and cranked it until they slipped out. I don't know if I bent the ears or not but at lease it is out. thanks for all the help..
Old Nov 28, 2009 | 09:57 PM
nathandennis1's Avatar
nathandennis1
If you dont have the special tools just take the drive shaft off and if you have a vice put a big socket that is bigger than the u-joint but smaller than the part of the drive shaft then take a smaller socket that fits onto the ujoint cap and press those together in a vice. its hard to explain but heres a pic that will really help.
http://myural.com/Driveshaft%20Repair1%20009.jpg
[IMG]file:///Users/student/Library/Caches/TemporaryItems/moz-screenshot.jpg[/IMG][IMG]file:///Users/student/Library/Caches/TemporaryItems/moz-screenshot-1.jpg[/IMG]
Old Mar 28, 2026 | 09:31 AM
samuel4wolfpack's Avatar
samuel4wolfpack
Even though most of the Dremels have one speed (whether it has a switch or a finger trigger) the amount of time can make a difference, whether the trigger is pressed one time and it stops, or whether the Dremel is turned on for a fixed number of seconds or minutes.
I thought I heard that people were able to use a pick or a small screwdriver to clean out the groove on the yoke. Sanding blocks by hand were mentioned... and if there was a dremel brush available that could fit in that groove, some people may want a higher level of precision in cleaning the groove after removing the old snap ring that holds the U-joint in place.
PaulTMurphy
Apr 20, 2017 12:15 PM
urbex
Feb 1, 2017 01:20 PM
herbiemin
Sep 7, 2016 08:20 PM
Grease & Gravel
Aug 13, 2016 03:38 PM
Joel Cassell
Jun 12, 2016 09:16 PM
