Drag link, pitman arm 1956 f100
Hi guys, a couple of quick questions...
Do the screws that go in the end screw ALL the way in? Should they be flush with the end of the drag link? I have tried my hardest to screw them in all the way, but I cannot get them to go any further than I have...hoping to hear that that's normal
Also, I installed an extended drag link from mid fifty (since I moved the axle forward with the springs) and with the wheels pointed forward, as close to aligned as I can guess, the pitman arm is not up and down...it doesn't seem like the drag link is the correct length. Real question is simply - with wheels straight ahead, the pitman are should be perpendicular to the drag link right (which should be as level as possible)?
Thanks!
Thanks!
On the drag link, I don't think it matters so much where the screws in the end, end up. The drag link slips over the ball stud on the pitman arm and steering arm and there are rounded wear cups that mate with the ball studs. The screws are there for 2 reasons; first, so you can put the drag link on the ball studs, and second so you can adjust the amount of play between the wear cups and the ball stud.
You want a snug fit but not super tight as these parts must move together. So, run the screws in until there is no play and then put the cotter pin in to hold their positions, grease them up and start driving
Bobby
Bobby
Sent from my iPhone using IB AutoGroup
On the drag link, I don't think it matters so much where the screws in the end, end up. The drag link slips over the ball stud on the pitman arm and steering arm and there are rounded wear cups that mate with the ball studs. The screws are there for 2 reasons; first, so you can put the drag link on the ball studs, and second so you can adjust the amount of play between the wear cups and the ball stud. You want a snug fit but not super tight as these parts must move together. So, run the screws in until there is no play and then put the cotter pin in to hold their positions, grease them up and start driving Bobby
The correct tool is called a drag link socket. See link blow.
http://www.ebay.com/itm/Snap-on-Vintage-1-2-Drive-Drag-Link-Socket-Model-No-A-17-Made-In-USA-/251472231767?pt=Motors_Automotive_Tools&hash=item3a8ce9bd57&vxp=mtr
Jack DK
01-04-2015 10:05 AM
50F2
04-30-2003 11:47 AM
