Super-special hidden engine kill switch....
Old Mar 9, 2014 | 08:26 PM
Serfbored's Avatar
Serfbored
Also known as a "quick fix" by PO ( PO was a gardener, I rescued this truck from a life of hard work) I am thinking he did as little as possible, just to keep this 1970 F250 2WD running.
Anyway, back to the super-secret kill switch. Directly below the ign switch, the PO mounted a simple toggle switch that must be on for the enging to run, and must be off to shut the engine off.
So, I am assuming a bad(stuck on) Voltage Regulator.
This switch has one wire cut into the red wire that runs between the + on the coil and the Dist. Other wire runs to the large + terminal on the solenoid.
I plan on, in the next day or two, removing the 135 amp alt from my sons '92 Sable, and installing it on my truck.
I guess my question is, does doing this alt mod solve my problem or does the PO switch create problems for my planned mod?
Not much of a wiring guy, but I can follow directions real gud
Old Mar 9, 2014 | 08:42 PM
Ford_Six's Avatar
Ford_Six
Bad ignition switch, bad resistor wire, or bad plug on the switch are the usual culprits. The VR has nothing to do with actually running.
Old Mar 9, 2014 | 09:07 PM
Serfbored's Avatar
Serfbored
Cool, switch was sticking a bit anyway, will order up a new one tomorrow. Resistor wire is the heavy gauge yellow one?
Am wanting to replace all the wiring and switches anyway, might as well start here.
Old Mar 10, 2014 | 01:03 PM
Ford_Six's Avatar
Ford_Six
The resistor wire is the pink one from the ignition switch to the coil. If you replace it and the coil is not specifically marked as a 12v no external resistor needed then you need to run a resistor or it will fry the coil. This one would work: http://www.summitracing.com/parts/ms...FecWMgodoXAA_w
I rewired a Jeep with the Summit 18circuit harness kit and it worked well. Before I scrapped the thing I pulled the kit back out and it will be going into my Courier once needed.
Old Mar 10, 2014 | 01:15 PM
JEFFFAFA's Avatar
JEFFFAFA
Courier!?!? Hmmm. Firewall mod and a 300 I6....................
Old Mar 11, 2014 | 01:17 AM
smokenchoken's Avatar
smokenchoken
I have a toggle switch on mine too but mines from a nasty electric gremlin stealing all my juice
Old Mar 11, 2014 | 11:51 AM
JEFFFAFA's Avatar
JEFFFAFA
That also can be the VR. Try temporarily unplugging it and see if your gremlin disappears.
Old Mar 11, 2014 | 12:14 PM
smokenchoken
i might wait a day or two to try it......
Old Mar 11, 2014 | 01:14 PM
Ford_Six's Avatar
Ford_Six
That was a previous build attempt. 6" into the firewall, and the pulleys were right behind the grille with the radiator in the bed.
This one's going diesel with a Mercedes OM617.
Old Mar 12, 2014 | 07:21 PM
kenny nunez's Avatar
kenny nunez
easy anti theft
Run a wire to the - or "dist" side of the coil then to a switch under the dash and a short wire to the other side of the switch and ground it. Try to conceal the wire. They will have to tow it or hijack you!
Old Mar 12, 2014 | 07:48 PM
Serfbored's Avatar
Serfbored
Looks like I will be delving a bit deeper into this. Earlier I picked up a new ignition switch, installed it, decided while I was there to have a look behind the dashboard for this pink resistor wire, and discovered that there was a wire with about 5 inches of the insulation melted off, and partially stuck to the pink resistor wire. Upon unsticking if from the pink wire, I seen the pink wire still had all of its insulation still on, so I tore the electrical tape off, and seen that the melted wire was red/brown, and also seen that there are two other wires, real close to where they are attached to the switch, that were also taped up.
Upon removing this tape, I discovered it is a heave gauge black and heavy gauge yellow which were damaged, also, there is a purple wire that is either a bit melted but most likely just chafed bare in one spot, perhaps a 1/4 inch long.
All in all, looks like I will be heading off the pick-a-part this weekend...it is their monthly 50% off weekend, and see if I can find the ign switch pigtail off of a willing donor.
Will probably also get the 3G alt for that swap while there, perhaps some GT40 heads as well.
Gotta love these almost direct bolt on mods.
Old Mar 15, 2014 | 06:33 PM
Thipdar's Avatar
Thipdar
Take a look at the write-up I posted this morning on the "Truck won't turn off" thread: https://www.ford-trucks.com/forums/1...-turn-off.html
It tells who does what to whom, how the switch is supposed to control what wires and what the gear ratios are for the electric dog polisher (ok, I made up that last bit).
The only thing I now realize I left out is the chart that references the wire numbers against their color codes. I think that chart is available here: http://www.fordification.com/tech/wi...wire-chart.gif
Old Mar 15, 2014 | 06:47 PM
Thipdar's Avatar
Thipdar
I think I'd rather ground out the field side of the coil, same as the ignition switch does.
aussiesteve
Nov 26, 2013 07:56 PM
TopThis8899
27
Sep 5, 2007 10:16 PM
BigShelby
Electrical Systems/Wiring
22
Jun 15, 2007 08:33 PM
dustinova
Dec 14, 2006 06:36 PM
fixingbus
1966 - 1977 Early Broncos
Mar 26, 2004 08:54 AM
