head gaskets any suggestions
Old Mar 9, 2014 | 07:15 PM
tofargone's Avatar
tofargone
So im doing the gaskets on my 6.0 in a couple of weeks im also doing the blue spring and a 4" straight pipe and an egr delete do you guys suggest anything else I should do while im in there
Old Mar 9, 2014 | 07:27 PM
9228.bobcat's Avatar
9228.bobcat
What year of truck?
Old Mar 9, 2014 | 08:32 PM
tofargone's Avatar
tofargone
Its an 04 extended cab with 210,000
Old Mar 9, 2014 | 09:46 PM
9228.bobcat
I would replace the dummy plugs, stand pipes, and oil cooler if it hasnt been replaced recently. Has your hpop been replaced?
Old Mar 9, 2014 | 09:51 PM
05F250DSL's Avatar
05F250DSL
Depends on the truck and your wallet. I'd put head studs in it while your there. How are you ect and eot temps running? If your delta is higher than 15* might do the oil cooler as well. If original hpop your in Or slightly past the mileage that I have them fail. Make sure you use ford oem head gaskets. If you have any stiction issues and have time look up the stiction fix thread and clean your injectors up. While the turbo is off take it apart and clean it. Clean the heck out of the intake as well. Maybe the updated oil feed and return lines.
Old Mar 9, 2014 | 11:34 PM
Yahiko's Avatar
Yahiko
Stick with OEM parts.
Sean
Old Mar 10, 2014 | 05:32 AM
tofargone's Avatar
tofargone
Dummy plugs??? I did the oil cooler about a month ago and the hpop I did it about 3 years ago give or take. The intake and turbo I cleaned them when I did the oil cooler. I am putting in the arp studs its the last thing I need to order just trying to get the wife to tern loose on the money for it ha ha.
Old Mar 10, 2014 | 05:54 AM
npccpartsman's Avatar
npccpartsman
Since an 04 may have an 03 or 04 motor you may or may not have dummy plugs. If the ICP sensor is on the valve cover you'll have an 04 motor. 04 and up motors have a "wave" high pressure oil rail that has a blind or dummy plug on the opposite end of the stand pipe. 04 wave rails typically don't leak like the 05 and up rails for whatever reason, but still a good time to update them while you're there. The OEM head gasket kits will come with updated standpipes. Order two of these and save some money vs. ordering a standpipe/dummy plug kit: Dummy rail plugs: W302908
PERFICUT L&L
Dec 9, 2020 06:49 AM
troverman
Apr 28, 2015 01:14 PM
mlytc
Apr 3, 2014 05:36 AM
EddieEX10
Jan 6, 2013 04:39 PM
stupidloud
Mar 2, 2012 02:58 PM
