Oil rail question
Old Mar 9, 2014 | 05:19 PM
spanky350's Avatar
spanky350
Oil rail question
I've been having a ton of problems with my early 03 and it failed the bubble test while cranking horribly. I just got the oil oring kits and oil rail cups w the new orings and tool to remove the cups. I took the drivers valve cover off and my oil rail doesn't look like the one in the tech folder. Mine is pretty much a straight rail. My question is is the kit I got from Bostech going to work in this rail?
Old Mar 9, 2014 | 05:23 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Yes, it will work. The Nipples are longer on the late style versus the early.
Josh
Old Mar 10, 2014 | 01:08 AM
run6.0run's Avatar
run6.0run
The bubble test has nothing to do with the oil rail. Your injectors are the issue. Either bad injectors,, or improper torque.
Old Mar 10, 2014 | 06:10 AM
78fordman's Avatar
78fordman
Pull the glow plugs 1 at a time and see when the bubbles go away. You need an injector oring kit, possibly an injector. Once narrowed down to which cylinder is pushing air pull that injector. If the Orings look fine you need a new injector. Torque the injectors to 28 ft lbs. Make sure the old copper washer comes out on the old one and oil or grease the new o rings going in.
Sent from my leash using IB AutoGroup
Old Mar 10, 2014 | 07:09 AM
spanky350's Avatar
spanky350
Yup, got it, just figured while in there I'd change the cups w new o-rings on the rail. I'm doing the new o-rings and washers on the injectors as well.
Racecar_Dave
Jan 6, 2018 10:47 AM
LSO1123
May 3, 2015 05:47 PM
whitetmw
Mar 18, 2015 10:02 PM
RRranch
Nov 27, 2009 08:25 AM
Craig64
Aug 28, 2007 04:50 PM
