As I understand how the wastegate works, you can't hear it in operation. It relieves drive pressure from the turbine side to the exhaust pipe downstream of the ex turbine. It doesn't function as an overboost blow off valve.
Correct, the sound heard is a reverse of air flow out the intake as pressures seek homeostasis.
i like things simple, so what Dan said is the Wastegate basically causes the truck to fart the excess.....while the sound heard is the burp from the intake.....most likely....
No, what is happening is the wastegate sensor is seeing an overboost condition, it tries to resolve the overboost by relieving drive pressure on the exhaust side of the turbo. Previous to the wastegate opening and reducing drive pressure, the intake side, (for all practical purposes, all the CAC tubing, the CAC cooler, right up to the intake valves) is seeing, say 30psi of pressure.
When the wastegate opens, the drive pressure falls, reducing the speed of the turbo shaft, which produces less pressure in the compressed side of the air intake. Say the tubing has 30psi in it, the wastegate opens, turbo slows and perhaps is producing 10psi....20 psi burps back through the compressor wheel and back into the air filter.
