How cold can you start?
Old Mar 7, 2014 | 06:40 PM
mg94mg94's Avatar
mg94mg94
Hello all, it's been a while since I've posted. Although I haven't started work on the truck that I mentioned in my previous thread (from a long time ago), so I haven't tried to start it yet. The -30 Celsius weather in my area yesterday got me thinking; how cold does your truck comfortably start? What was the coldest you've started it? Fahrenheit or Celsius welcome.
The conversion is:
F = Cx9/5 + 32
Conversely:
C = (F-32)x5/9
Old Mar 7, 2014 | 06:57 PM
tjc transport's Avatar
tjc transport
i ain't rite
-15F was the coldest.
just last month -10F and it has almost 494,000 miles on it. (i was wrong with the 497, i looked on monday when i moved it)
and i never plug it in.
Old Mar 7, 2014 | 07:54 PM
jayro88's Avatar
jayro88
Plugged in mine always fires up, or at least so far. It got down to -15* to -20*f. Wind chill was 30 below. Started up fine but figured out I had gotten some bad fuel when it stalled out agian. Had to crawl under it with a hair dryer to de-ice the fuel line.
There were a couple of times when I forgot to plug it in and it got down to about 0*f at night. Cycled the gp's 2 or 3 times and fired right off. No high idle or timing advance......sensor is bad.
Old Mar 7, 2014 | 08:07 PM
Macrobb's Avatar
Macrobb
I'll point out that I've not plugged it in, in the two years I've been driving it to work.
For me, somewhere around 10/15F. When it got that cold, I had horrible trouble -- I suspect the fuel was starting to cloud/gel, because my IP sure didn't want to inject much of anything(despite having pressure at the filter). Took me a few minutes, but I finally got it started with quite a bit of ether and praying.
After that, I started mixing in plenty of Diesel anti-gel additive while it's been really cold, and haven't had any issues since.
Anywhere over 20F, it starts just fine on GPs(if I have a least 6 or 7 working - manual system).
Old Mar 8, 2014 | 04:38 PM
kc0stp's Avatar
kc0stp
-15F is the lowest Ive gotten it (not plugged in)
Old Mar 8, 2014 | 05:19 PM
jayro88's Avatar
jayro88
How many times did you cycle the glow plugs?
Did you notice that it turned over slower? Once the temp gets down to about 0 I have noticed mine turns over alot slower if it has not been plugged in.
Old Mar 8, 2014 | 11:19 PM
Red454sedgwick's Avatar
Red454sedgwick
Your timing makes a big difference. I had mine at 10btc and it would start in single digits, then I backed the timing to 7btc and you better have it plugged in at around 20f or it's not going to start, but it's a 300,000 mile plus motor that needs valve work.
My other that I just rebuilt, but with .060 shaved off the pistons, will start in single digits, but it's tough. The timing on it is at 7 too. I'm going to switch my oil to 10-40, that was a big help with my ex's 6.5t suburban.
Old Mar 9, 2014 | 01:20 AM
kc0stp's Avatar
kc0stp
Once, only tried it to see if it could as a worse case scenario (normally drive my Miata as its a lot cheaper ) as far as cranking speed, it cranked a little slower but not bad, without a doubt a lot better then the Mata does for sure (half the time when it gets down to single digits Im wondering if I need a jump box, 1-2 slow revolutions and it fires right up though)
Old Mar 9, 2014 | 01:01 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
(this is with chip truck.)
sure was a mean winter.hit some nasty lows.mine started right up -20F.the batteries took a hit from the cold,you could tell she didn't spin fast,but within a few seconds after one normal cycle of the gp's without a block heater,she fired up.
i do seem to have a drain,cus after a couple weeks without starting it,she did need the batteries charged up.think i had to put it on the charger twice this winter.maybe 3 times.if i was running the truck much i probably wouldn't have had to.
7.3l
banks sidewinder
dual 850cca
3/awg bat cables
duralift e-pump
engine timing @ 7 BTDC/2k rpm
lil over 100k miles
fresh ip (IFS reman)
fresh (new) factory turbo stanadyne fuel injectors/G codes
oem gp system (fully tested/cleaned connections.)
completely replaced fuel system (minus a pickup with pin holes in rear tank.use front tank only.)
block heater condition = unknown (iv seen the cord,so i know there is one lol.)
autozone reman oem Mitsubishi starter
mobil 1 turbo diesel truck 5w-40 synthetic motor oil
she starts easier than my little 4 cyl in my mazda beater car.iv never had a gas engine start anywhere near as easy as this engine does.wasn't always the case.previous owner neglect was the cause of very poor (even when warm out lol) cold starts when i bought it.
Tom
6.7L Power Stroke Diesel
Dec 14, 2010 07:15 AM
kirkharrod
Dec 7, 2009 07:26 PM
RussellF
Jan 16, 2009 10:26 AM
aladin sane
Apr 14, 2007 09:48 PM
WJC
Feb 9, 2007 09:53 AM
