Sponsored by: Real Truck
Blank Axle Code??
Old Mar 7, 2014 | 10:19 PM
skyfox10's Avatar
skyfox10
Originally Posted by Psyclopse
Mine has paddle mirrors. Unfortunately...
Other guy at work with a super duty has paddle mirrors too. Noticed it today when I went out to check on the axle code and saw his parked next to mine.
Old Mar 8, 2014 | 02:21 AM
Yahiko's Avatar
Yahiko
One thing to try before you buy. Clean the space around the VSS sensor and then
pull it out and wipe the end off and put it back and retry. Also check the plug
for any green death. (Corrosion) on the contacts. That can also screw it up. Clean
with contact spray cleaner and use some dielectric grease to help protect it from
water and SALT.
Also if you do find a lot of junk on the sensor end you may want to change the
fluid in the differentials to be safe.
Please keep us posted on how things are going.
Sean
Old Apr 17, 2024 | 08:21 PM
Blossom2022!!'s Avatar
Blossom2022!!
1st Gear
2000 f350
Originally Posted by skyfox10
Wow. More info that I would have ever expected. Thank you guys very much.
I did end up buying the truck today. It's a little bit of a basket case, as the speedo worked when I started the test drive and didn't by the time I got back. After the speedo quit, the OD Off light started blinking.
The owner said it started doing that after he changed the transfer case about 8000 miles ago. I'm now kind of wondering how he managed to break the axle and transfer case on this thing.
Besides that, just a bunch of little things:
Missing clip around air box
Check engine light
Truck almost seems like it will stall when put into gear but drives fine
Bad exhaust leak on pass side due to broken studs
Gonna pull codes and do some tinkering tomorrow after work. expecting bad/dirty sensors or vacuum leak at play here, maybe PCV.
Here are a few pics of the truck before we aired up the tires.
I have the same problem I my door tag there’s no axle info what did you find on your axle?
Old Nov 25, 2025 | 02:02 PM
twixti's Avatar
twixti
1st Gear
Originally Posted by redford
Primary Features
Build Date: 20.12.1999
Vehicle Line: F250/350/450/550 Super Duty
Body Style: Super Single Cab
Version: 250 Series
Engine: 6.8L SOHC EFI NA V10 Gas
Transmission: E4OD(4R100)
Drive: LHD 4WD (PTD)
Axle Ratio: 3.73
Emission: With 49 State Emission Requirements
Air Conditioning: Manual Air Conditioning
Paint: Ebony
Minor Features
Medium Parchment
142"/3607MM Wheelbase
XLT
Kentucky Truck Plant Build
Less Special Equipment Package
With Camper Pack
With Snowplow Pack
8800 LB. GVW
With Off Road Appearance Pack
With Power Equipment Group
With Privacy Glass
With Sliding Rear Window
Floor Cover - Vinyl Ins - Complete
Dual Sail Telesc TT Mirror-Manual
With 2nd Row Bench Seat - 3 Passngr
With Front Towing Hook
Rear Bumper - Steel Step - Chromed
With Front Licence Plate Bracket
With Driver Air Bag
With Passenger Air Bag
With Steel Spare Wheel
7.0 X 16" Forged Aluminium Wheel
LT235/85R-16E BSW A-S Tyres
With Conventional Spare Tyre
3.73
Rear Axle Limited Slip Differential
Electric Trans Case And Auto Hubs
With Mid-Ship Fuel Tank
With Tilt Steering Wheel
With Speed Control
Elect AM/FM/Stereo/Cassette/Clock
With Aero Headlamps
Roof Marker/Clearance Lights-Conv
Ebony
Hi, maybe you can help me with gear ratio?
On sticker axle blank.
1FMNU43SXYEB39559
Excursion V10 6.8 2000year.
Old Nov 26, 2025 | 08:52 AM
WE3ZS's Avatar
WE3ZS
1FMNU43SXYEB39559
With stock sized tires does it rev over or under 2K at 60 MPH? The standard EX ratio was 3.73 (under 2K) and 4.30 (over 2K) was the only other option.
Truck Guy99
Jul 29, 2014 06:48 AM
macmccrary
Jul 13, 2009 03:58 PM
fordzrule
Jul 5, 2008 10:35 AM
lardman
Mar 17, 2005 01:21 PM
GendoIkari69
Mar 2, 2005 10:59 PM
