223 oil filter ?
Old Mar 16, 2014 | 01:28 PM
hiball3985's Avatar
hiball3985
Originally Posted by GeeeMCeee
Thanks Jim, TDC, well......not exactly sure to determine combustion stroke.
The easiest way is remove the distributor cap and turn the engine over by hand and see what cylinder the rotor is pointing to. Start with #1, the next will #5 3 6 2 4..
There is a possibility considering the description of your old oil condition that some of the lifters may have gummed up in an open position if the engine sat for a long period without being turned over. You have to be sure the lifter is seated against the cam before checking the clearance.
Old Mar 17, 2014 | 07:36 PM
GeeeMCeee's Avatar
GeeeMCeee
Jim
Thanks again, changed the oil after much cleaning, added some seafoam ran for about 20 min then adjusted the valves, ran again for 20 min and readjusted the valves. Before all this I had 2 cyl @ 0#, 3@ 100#, 1@ 50#. Now have 3@ 110, 1@ 125, 2@ 95, don't know if it will improve any more or not. The 2@ 95 were read last when the battery seemed to be getting low. Looks like two push rods are bent - can they be straightened or just trashed? Just don't know what to expect out of this motor, after it was so neglected. If I could get it to run for a year or so.......
Old Mar 17, 2014 | 08:29 PM
real550A's Avatar
real550A
Sounds like great progress, those compression #'s are good enough to run.
Worst case, you can straighten pushrods, but I would ask around here, somebody has a box full of straight ones to spare, I'd bet.
Run the seafoam during your next two or three oil changes, it will clean that
engine right up.
Old Mar 17, 2014 | 08:44 PM
hiball3985's Avatar
hiball3985
Thats great new, you should be on the road in no time . Change the oil filter also, all that stuff that is loosing up will plug it up pretty quickly. Replace the push rods to be safe.
Turbo Dog
2009 - 2014 F150
Dec 12, 2016 10:45 AM
mountainhoundf350
6.7L Power Stroke Diesel
Dec 4, 2012 01:43 PM
hikeril
22
Feb 27, 2012 11:14 PM
cps
Jul 19, 2008 05:19 PM
texas_vet
Feb 20, 2006 10:40 AM
