Heater core
Old Mar 1, 2014 | 01:11 PM
vettman's Avatar
vettman
Heater core
I have a '76 F350 Ranger XLT extended cab pickup with 460 and factory air. Starting to smell anti-freeze in the cab, but floor below heater/blower is not wet. I'm waiting for warmer weather to replace thermostat housing gasket which is "weaping". Could be the blower is picking up the smell from that. Regardless, since I'm still on the factory heater core I think it wise that I find a source for a replacement. I would appreciate one of you pros giving me a source and part no. I've searched the web, and I see there several sources, but not sure any are the exact replacement I'm looking for.
Thanks
Old Mar 1, 2014 | 01:25 PM
MontanaboyDesigns's Avatar
MontanaboyDesigns
I might do the same this spring, probably just go with a NAPA heater core. This model or similar.
NHC 6603001
http://www.napaonline.com/Catalog/Ca...001_0302748887
Old Mar 1, 2014 | 01:31 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Factory installed A/C is combined with the heater. The A/C controls are in the same panel as the heater controls.
D3TZ-18476-A .. Heater Core-Use with Factory Installed Integral A/C or High/Low Comfort Vent System / Obsolete
Applications: 1973/79 F100/350 & 1978/79 Bronco.
Any radiater shop can recore a heater core.
Old Mar 1, 2014 | 02:21 PM
User 71024's Avatar
User 71024
<table style="margin: 0px; padding: 0px; border: 1px solid black; border-collapse: separate; background-color: white;" class="main" cellSpacing="0"><tbody><tr id="table2part0" class="part0" name="pltr2"><td class="alternate0" rowSpan="2"><table class="parts"><tbody><tr><td style="margin: 0px; padding: 0px;" class="left"><table style="margin: 0px; padding: 0px;" class="layout"><tbody><tr><td class="partlayout">PRO Part # 9010045 <input id="node2part0moreinfo" class="moreinfo_default" title="Click for more information about this part" value="Info" type="button"> {#C5D718476A, C5DE18476A, D3TE18476A, D3TZ18476A}
Category: Heater Core</td></tr></tbody></table></td><td style="height: 40px;" class="right">
</td></tr></tbody></table></td><td style="padding-top: 10px;" id="node2part0price" class="center leftrightborder boldfont priceonly alternate0">$27.79</td></tr><tr id="table2add0" class="part0"><td style="padding-top: 5px; padding-right: 5px; vertical-align: top; white-space: nowrap;" class="alternate0 center"><input id="node2part0addtocart" class="addtocart_default" name="addtocart" value="Add Part" type="button"></td></tr></tbody></table>ROCK AUTO
Old Mar 1, 2014 | 03:33 PM
ranger429's Avatar
ranger429
NHC 6603001
NAPA AUTO PARTS
That core is for no A/C.
Aluminum JUNK.
Original brass core.
1973-79 BRONCO HEATER CORE - WITHOUT A/C - BRASS | Laurel Mountain Mustang
Old Mar 1, 2014 | 03:34 PM
vettman's Avatar
vettman
heater core
Do you know if this one requires any mods or is it identical to the OEM? Because of tight quarters and general PITA to replace, I don't want to have to mod anything.
Old Mar 1, 2014 | 03:36 PM
ranger429's Avatar
ranger429
Which one?
That aluminum Spectre pile of crap from Rock Auto will require making your own gasket.
The one I posted from Laurel Mountain Mustang is a direct bolt in.
MontanaboyDesigns
Aluminum JUNK.
Yeah, that's a whoops on my end, that's pretty much the one I'm getting because I have no A/C. But Napa has the one he's looking for. In my experience Napa parts are decent for these old dents.
Old Mar 1, 2014 | 03:40 PM
ranger429's Avatar
ranger429
NAPA will not have a brass core, they are pretty much extinct. I spent several days tracking the core I posted above down when I replaced mine a while back.
Old Mar 1, 2014 | 04:09 PM
paredneck33's Avatar
paredneck33
It's hard to tell. Is that one copper or brass. I got a copper core replacement a couple of years ago for my pickup from Autozone. So far so good.
Old Mar 1, 2014 | 04:15 PM
MontanaboyDesigns
That Laurel Mountain one is pretty tasty.
Old Mar 1, 2014 | 04:54 PM
ranger429's Avatar
ranger429
The Rock auto image is aluminum, you can tell by the crimped on fittings. A couple of years ago they were easy to find. Within the last year or so it seems everyone is simply offering the Spectre brand.
Tasty? If you mean expensive I guess you get what you pay for. I'd rather have an original core and use the OE gasket than save 20-30 bucks and have to make a new gasket out of foam padding.
I now have 2 or 3 OE cores in stock. Ran across a couple on ebay and didn't hesitate to buy them.
Old Mar 1, 2014 | 04:59 PM
arctic y block's Avatar
arctic y block
Stay away from aluminum Chinese cheap chit. I just went through three of them. The kept
blowing out under hard acceleration like passing. ND Bill found me the part# for the Ford
part and I ordered that. Of course the sent the wrong one as it had the wrong pipes
on it for my application. To short and bent the wrong way. So I took my original Ford
core and the new one to a freind that has a furnace and appliance pluming type
business. He un-soldered the wrong pipes and lead soldered in the correct ones.
It has worked flawlessly now for about 4/5 months. So go with Ford factory parts.
Where ever ya can. It's worth the extra bucks.
Why didn't I ship the core back and get the right one? Look into shipping to Alaska,
especially if it is trucked through Canada.
njdevil77
Mar 28, 2018 08:16 PM
midsouth
Nov 13, 2017 03:57 PM
bpimm
Sep 30, 2017 10:36 AM
highoctane74
Apr 24, 2013 09:59 PM
Mudman
Feb 13, 2006 10:48 PM
