Engine Water Temp.
Old Feb 28, 2014 | 09:06 PM
66 sandrail's Avatar
66 sandrail
Engine Water Temp.
I am sure this has been discussed before but did not find a thread on it.
Here goes......I have a 78 F 150 that I purchased from a previous owner that has a 460 out of a 75 Lincoln. The PO had a new radiator put in the truck and it looks to be the right radiator for the application with the previous 351 M that was in the truck originally.
The problem I am having is when I drive the truck at about 65 to 70 mph for a distance of 5 to 10 miles the temp gauge does not show that the engine is running hot but when I stop and turn the engine off and after a few minuets get back in to restart the engine it is hard to start and the temp gauge will show that the engine temp is hot but not in the red zone. After the engine starts it will start to cool down immediately. The water level is full and it does not seem to be pushing any water out the over flow hose.
The engine does not have a fan shroud (which I know it needs one to operate normally) but was wondering if there is any other reason to cause the engine to do this. And it does have AC on the engine but does not work.
Please help......Thanks in advance!!!
Old Feb 28, 2014 | 09:14 PM
Jklnhyd's Avatar
Jklnhyd
Fan shroud is the only reason so far.
The fan sucks air thru the radiator because the shroud is in place. Without the shroud, its like sucking water through a straw, with using a straw
Old Feb 28, 2014 | 09:55 PM
HIO Silver's Avatar
HIO Silver
Do not rely on the stock gauge. They are inherently inaccurate. Install a quality aftermarket gauge with its matching sender to get the true temp reading.
Yes, run a shroud. Your engine will thank you.
Old Feb 28, 2014 | 10:10 PM
Dave145's Avatar
Dave145
Sounds to me like it's heat soaking once it's parked. Hence why it cools off as soon as you start driving it. Really kinda sounds normal to me.
Then again the shroud will help cool the engine BEFORE you park it so...that could prevent the heat build up I suppose...
Old Feb 28, 2014 | 10:14 PM
Blue and White's Avatar
Blue and White
Agree. Iron head engines in general heat up after brief shutdown (heat soak). Sounds normal.
Old Feb 28, 2014 | 10:20 PM
turbohunter's Avatar
turbohunter
There could be a few things going on here.
First off, when you stop your truck the water stops circulating and the engine gets hotter. So when you come back out after a few minutes your engine is so hot it's difficult to turn over. This is a normal deal. What is wrong in your case is that your system may not be doing well before that.
To find the problem you need to check anything that could contribute to your engine running on the hot side. Could be one thing or a combination of 2 or more. If it's running hot. As HIO said you may have a mixture of parts giving you bad info.
Radiator?
Pump?
Timing?
Blockage somewhere? (like heater core)
Headgasket?
And I'm sure there are a few more I forgot about.
The first thing I would do is check your timing.
If it's to advanced it can be hard to turn over. Made worse when hot.
Good luck.
Old Mar 1, 2014 | 06:03 AM
gatorfor88's Avatar
gatorfor88
Is it hard to start because it doesnt want to turn over,or hard to start because it doesnt want to crank? If it turns over easily I would change the stator aka pickup coil in distributor. Notorious for getting hot and causing hard starts. If it doesnt want to turn over easily sounds like starter dragging. New starter causes a lot less draw on electrical and will usually fire right up even hot.
Old Mar 1, 2014 | 10:52 AM
66 sandrail
gatorfor88......it turns over like when the timing is set a little high but it starts quickly.
there has been a water pump replaced by PO also.
don't know how many miles are on engine but when I checked the slack in the timing chain by slowly moving the distributor back and forth it seem normal.
As long as i don't drive it very hard it doesn't do this. I normally drive around 50-60 mph to keep this from happening till I figure out what to do to correct it.
I will check the items y'all spoke about in this thread and see what I come up with.
Thanks and if anyone else has an idea please throw it my way!!
Old Mar 1, 2014 | 11:29 AM
fuzzybob's Avatar
fuzzybob
Sandrail.... have you tried a heat insulating carb spacer?? Might keep the heat soak from getting to the carb.
Good luck with it.
Old Mar 1, 2014 | 05:53 PM
66 sandrail
Not yet fuzzbob.......I got my heat gun with me and the next time I take it for a ride I am gonna run her pretty hard and take reading's with the heat gun to see what the temp is at different places.
Will get back to the thread with some figures and location's.
Thanks for y'alls
help!!!
Howard5091
Jul 28, 2017 06:10 AM
D Sokol
Aug 20, 2016 01:16 PM
db1068
Aerostar
Jul 6, 2015 09:03 PM
imjwm
18
Oct 17, 2011 08:37 PM
Little Bro
17
Sep 4, 2004 05:37 AM
