Drain Plug
Old Mar 7, 2014 | 06:52 AM
bismic's Avatar
bismic
Originally Posted by KDAVID1
When replacing this drain--do you just take the old out and put this one in or do you have to take the plate off to install it?
You do not take the plate off, unless you think it has been damaged somehow.
Old Mar 7, 2014 | 10:57 PM
olfordsnstone's Avatar
olfordsnstone
Originally Posted by jeffie_3
So they use brass as a sacrificial anode? Interesting...
I'm pretty sure that Yahiko's post was stating the opposite, that it is not a sacrificial anode for corrosion as the originals are simply steel. I believe the purpose of the brass replacement plug is so the brass threads would strip if overtightened or cross threaded rather than the HFCM, since brass is softer than the HFCM. Though the replacement (brass) plugs are only needed to be finger tightened, I think that would be the purpose of using brass.
Old Mar 7, 2014 | 11:15 PM
Yahiko's Avatar
Yahiko
Diesel is not really a conductive fluid and there for would not need
to have a sacrificial anode at all. It more that the byproducts of the
algue are chemical corrosive.
Brass is less reactive with aluminum than steel. I used to have a
chart that showed what metals reacted with each other.
Sean
Old Mar 8, 2014 | 09:59 AM
KDAVID1's Avatar
KDAVID1
Perfect. Thanks
Old Mar 8, 2014 | 10:19 AM
KIDkiser's Avatar
KIDkiser
Wouldn't you know it, mine just came in the mail,and I just drained mine yesterday.Im not taking another fuel shower.
Old Mar 8, 2014 | 12:45 PM
KDAVID1's Avatar
KDAVID1
My wife is still mad at me for bringing diesel soaked shirt in the house lol
BII Plow Truck
Oct 26, 2017 07:14 PM
akblackfoot
Aug 18, 2016 06:29 AM
mudrat025
Jun 13, 2014 10:43 AM
mad modder
18
Oct 13, 2008 09:49 PM
yomamaha
Jul 14, 2003 11:43 PM
