battery drain
Old 02-27-2014, 06:19 AM
colson327's Avatar
colson327
colson327 is offline
battery drain
Any ideas on what can cause my 8v battery to drain down over a week of downtime? I've checked all I could think of. Starts everytime if I just disconnect the Pos. grnd cable from battery after using. Is charging while running, generator was tweeked to allow for 8v battery. I have no radio, vacuum wiper, maybe a fault in the turn signal? Thoughts? Also, my horn don't work, never has...
Old 02-27-2014, 06:49 AM
Branded's Avatar
Branded
Branded is offline
Might be the voltage regulator . Unplug it and see if it has any effect. Other thing is put a test light between battery post and cable. If you have a draw on the system the light will light up. If it lights up start pulling fuses on at a time. When the light goes out you found the circuit that is drawing.
Old 02-27-2014, 08:48 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Agree on the voltage regulator cut-out relay, although I would be surprised if it takes more than overnight to drain if it's that.
Old 02-27-2014, 09:06 AM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
Brake lights staying on? Very common for a bad pressure switch to keep the brake lights on. Usually quite obvious. Battery known good?
Old 02-27-2014, 01:03 PM
harleymsn's Avatar
harleymsn
harleymsn is offline
I put a volt meter on mine, wired it directly to my alternator. When the truck sits it actually drains the battery. I guess I need to wire it through the ignition.
51MHF5
18
07-16-2013 07:44 PM
Fordy Four
04-23-2008 05:59 PM
mahanson
Electrical Systems/Wiring
10-01-2004 03:05 PM
GeneStoner
03-18-2003 11:04 AM
petr
12-11-2001 02:04 AM
Quick Reply: battery drain
