Chasing down a battery drainer...
Old Mar 13, 2003 | 11:39 PM
GeneStoner's Avatar
GeneStoner
I have a '74 F100 that I recently put a new engine in. While I was at it, I also replaced the, Battery, the cables, the starter and solenoid ad nauseum...
But something in the truck is now causing the battery to drain it's charge over night. I put a meter on the (-) battery terminal and the (disconnected) -- cable and it showed it was draining about .18 Milliamp with everything turned off and all fuses removed.
Without having to go through the entire electrical system to find the culprit (which I may still have to do), any ideas on where I should check?
Old Mar 14, 2003 | 09:32 AM
BB's Avatar
BB
Do that same test but with the voltage regulator unplugged too.
Barry
Old Mar 14, 2003 | 10:54 AM
thelonerangerxlt's Avatar
thelonerangerxlt
Check the mercury switch that turns the under-hood light on. Then check the sun visor courtesy lamps (if equipped). Make sure the hazard light switch is completely turned off.
It might also be an internal drain in the ignition switch itself. You could try jiggling it with the milliamp meter connected.
A drain like yours drove me crazy a while back on my daughter's Mustang. It turned out to be the visor courtesy light not turning off. With the visor in the upright position, no one could see the bulb staying lit.....
Old Mar 14, 2003 | 11:02 AM
Bob Ayers's Avatar
Bob Ayers
A drain of .18 milliamps (180 microamps) will not drain your battery overnight.......Try letting your battery set overnight
with the negative terminal disconected and see if it still goes
dead. If it does, your battery is bad...
Old Mar 14, 2003 | 03:33 PM
BB's Avatar
BB
You're right, I was assuming he meant 180mA but that's still not enough to drain a battery overnight. If a battery has an 80A/H rating it should be able to deliver 4 amps over 20 hours until it hits 10.5 Volts.
barry
Old Mar 14, 2003 | 08:20 PM
steve83's Avatar
steve83
This doesn't pertain directly to this thread, but it's good reading about batteries.
Old Mar 18, 2003 | 03:59 AM
deano512's Avatar
deano512
Try doing the battery drain checks with all the fuses Installed. Note the reading, Then remove 1 fuse at a time and note the reading. Re-install the fuse and then do the next fuse...and so on.
Note: take a look at the thread labelled "Battery Drain" from Mkrog. It should help you out..
Let us know how you make out & Good Luck
Deano
Old Mar 18, 2003 | 08:44 AM
Howdy's Avatar
Howdy
The current drain sounds about right for memory power on the radio. Is it wired direct?
You didn't say if the battery was totally dead or just drained enough not to start.
I see you replaced about everything, but I don't see the alternator listed. Get the truck running, turn lights and heater fan on and check your voltage output.
If the charging system checks OK it might just be the ignition switch. I have a 76 F100 that I had to replace the switch on. They just get old and intermittant...
Old Mar 18, 2003 | 11:04 AM
Mil1ion's Avatar
Mil1ion
Click the link below to find a short.
http://www.inliners.org/tech/tech6.html
