390 distributor
Old Feb 26, 2014 | 05:49 PM
aj3501's Avatar
aj3501
390 distributor
Has anyone tried out this distributor?
Ford FE 352 360 390 427 428 Hei Distributor 6508 R | eBay
The seller has 24k positive feedback vs 75 bad.
Old Feb 27, 2014 | 04:18 PM
69cj's Avatar
69cj
No I haven't but it looks like a Davis Unified HEI Distributer. It's basically a copy of GM's first electronic dizzys. Save yourself some money and just install a Pertronix unit inside your stock dizzy. They work great.
Old Feb 28, 2014 | 09:49 AM
MIKES 68 F100's Avatar
MIKES 68 F100
I have the Blue version , works great . only bad to me is size . I recently put new after market gauges in my truck , I had to lift Dizzy about an inch to get temp sensor out and in on intake . Also get the one that comes with wires , wire connections at dizzy are totally different .
Old Mar 1, 2014 | 01:19 PM
KO1960's Avatar
KO1960
I have the stock dizzy with the Pertronix, and it is a fairly tight fit on my '65 F250. I wouldn't consider the HEI, because of the space issue and the fact that the Pertronix works great. Good luck.
Old Mar 2, 2014 | 10:15 AM
bertha66's Avatar
bertha66
I did work on a 71 360 that had one of these, size was a problem.
Old Mar 6, 2014 | 07:50 PM
yetiman38237's Avatar
yetiman38237
Betting it would hit bottom of my air breather
Old Mar 6, 2014 | 08:19 PM
1972RedNeck's Avatar
1972RedNeck
It would. I would never run any other ignition system though.
I bought mine from CRT Performance. It came with wires.
Old Mar 9, 2014 | 09:31 AM
yetiman38237
still running points.....bought Accel eliminator and all it did was empty my wallet......
Old Mar 17, 2014 | 10:43 AM
orich's Avatar
orich
I also running the HEI dizzy and have tried all 3 Pertronix units. The HEI seems to be a step up from the Pertronix unit IMO!
Like said above, the down side it's big and ya got a use a carb spacer for stock air filter.
And for some may need to add carb linkage from adding card spacer.
The other up side is the ease of auto parts store replacement parts.
And a cleaner looking engine bay area.
orich
Old Mar 17, 2014 | 11:45 AM
aj3501's Avatar
aj3501
with how your dizzy is set up in your picture where did your Number one spark plug end up being at
Old Mar 17, 2014 | 12:58 PM
orich's Avatar
orich
I moved #1 over too #5 hole so looking at the center of dizzy coil #1 is first top left only for better fitment as, I have a holly cross over hard chrome fuel pipe running behind my dizzy. So not enough room to drop the wire down out of the way. Plus it looks better this way..
orich
Old Mar 18, 2014 | 05:40 AM
yetiman38237
Since I am already running a carb spacer due to spread bore carb on square bore manifold it ought to work for me. I put the Ford HEI cap on and it barely clears now.......
FordStolz68
Apr 17, 2015 08:52 AM
sweetlou1
Aug 20, 2013 07:21 PM
9d4
Jun 10, 2009 06:12 AM
KEN1975
Feb 28, 2008 04:04 PM
